TUTORIALS ESP32
ESP32 Arduino Tutorial: Websocket server
DFRobot Nov 10 2017 263435
The objective of this ESP32 Arduino Tutorial is to explain how to create a Websocket server on the ESP32, using the Arduino core as programming framework. The tests of this ESP32 tutorial were performed using a DFRobot’s ESP-WROOM-32 device integrated in a ESP32 development board.
The objective of this post is to explain how to create a Websocket server on the ESP32, using the Arduino core as programming framework. Our Websocket server will act as an echo server, which will return to the client any data that it sends.
Since we will need to test our server, we will develop a very simple client on Python. Even for those who have not used Python yet, it is a very simple (yet powerful) language, so it should be easy to follow the code shown below.
Nonetheless, if you still don’t feel comfortable with using Python, you can test the code with the ESP32 Websocket client from the previous post running on another ESP32 or use a Websocket API from other programming language you feel comfortable with.
The tests of this ESP32 tutorial were performed using a DFRobot’s ESP-WROOM-32 device integrated in a ESP32 FireBeetle board.
The Arduino library
On the ESP32 side, we will need to install a Websockets library, so we don’t need to code the low level details ourselves. We will use this library, which works on top of the WiFiServer that is usually used in the Arduino core for creating a TCP server.
Please note that the Websockets library mentioned is not, at the time of writing, officially supported on the ESP32, but rather on the ESP8266. Nonetheless, with a few changes, we will be able to use it on the ESP32.
The installation details for the library are explained in this previous tutorial. Please consult it first since there are a few tricks that need to be taken in consideration before using it.
The Arduino code shown below is based on this example from the library, changed to work with the ESP32.
The Python module
We will also need to install a Websockets module on Python, again to abstract the low level implementation details of Websockets.
We will use a Python module called websocket-client. Fortunately, Python installations come with a package installer called pip, which makes installing modules very simple.
Thus, to install the mentioned library, we simply need to send the following command on a Windows command line:
pip install websocket-client
Note that depending on the way your Python version was installed, you may need to navigate to the folder where pip is located before sending the previous command.
The Python code
We will start by importing the websocket client module we have just installed. We will also need to import the time module for introducing some delays in our program.
import websocket
import time
After this, we will need to instantiate an object of class WebSocket, from the previously imported module.
ws = websocket.WebSocket()
Then, we simply call the connect method on our WebSocket object, passing as input the address of the server.
Note that since this is a websocket connection, we specify the destination with “ws://{serverIP}/“, where the server IP will be the one assigned to our ESP32 when it connects to a WiFi network.
Note that I’m using the IP of my ESP32, which I already know what is when connected to my home network. Nonetheless, in case you don’t know yours yet, we will print its value on the Arduino code.
ws.connect("ws://192.168.1.78/")
After this call, we should be connected to the server. Note that I’m not doing any error handling for simplicity, but it is important to do it in a final application.
Next, to send data to the server, we simply need to call the send method of our WebSocket object, passing as input a string with the content.
ws.send("data to send")
To receive data from the server, we simply call the recv method on the WebSocket object. This method returns the data from the server, if any is available, and thus we should assign its value to a variable.
result = ws.recv()
Finally, to disconnect from the server, we need to call the close method on our WebSocket object.
result = ws.close()
You can check the full source code for the Python Websocket client below. Note that we are now sending and receiving the requests on a loop and printing the data obtained from the server to confirm that it is indeed echoing the content.
You can change the nrOfMessages variable and the sleep time to test the resilience of the server to more requests and shorter intervals between requests.
import websocket
import time
i = 0
nrOfMessages = 200
while i<nrOfMessages:
    ws.send("message nr: " + str(i))
    result = ws.recv()
    print(result)
    i=i+1
    time.sleep(1)
ws.close()
The arduino Code
Includes and global variables
We will start our Arduino code by including some libraries. We will need the WiFi.h library, which allows us to connect the ESP32 to a WiFi network, and the WebSocketServer.h library, which will expose the functionality needed for us to set up a websocket server.
#include <WiFi.h>
#include <WebSocketServer.h>
Next, we will need an object of class WiFiServer, so we can create a TCP server and make it listen for incoming requests. The websocket server will be built on top of it.
One of the optional parameters of the constructor of this class is the port where the server will be listening. Although its default value is 80, we will explicitly pass this input for illustration purposes.
WiFiServer server(80);
We will also need an object of class WebSocketServer, which exposes the methods needed to receive requests from clients and handle the data exchange.
WebSocketServer webSocketServer;
To finalize the global variables declaration, we will need to store both the WiFi network name (ssid) and its password, for later connecting to it.
const char* password = "yourNetworkPassword;
The setup function
Moving on to the setup function, we will start by opening a serial connection to output the results of our program.
Then, we will connect the ESP32 to a WiFi network and print the local IP that is assigned to it. That is the IP that you should use on the previously explained Python code.
Please consult this previous post for a detailed explanation on how to connect to a WiFi network on the ESP32.
Serial.begin(115200);
WiFi.begin(ssid, password);
    delay(1000);
Serial.println("Connected to the WiFi network");
To finalize the setup function, we will initialize our TCP server by calling the begin method on the WiFiServer object. This method receives no arguments and returns void.
server.begin();
You can check the full setup  function code below.
void setup() {
    delay(1000);
  server.begin();
  delay(100);
The main loop
We will handle the client connections and the exchange of data on the Arduino main loop function.
First we will listen for incoming connections by calling the available method on our WiFiServer object. This method call will return an object of class WiFiClient.
Note that in this step, we are still working at the TCP client level and not at the websocket client level.
WiFiClient client = server.available();
Next we check if the TCP client is connected simply by calling the connected method of the previously returned WiFiClient object, which will return true if the client is connected and false otherwise.
We will also call the handshake method of our WebSocketServer object (a global variable we declared at the beginning of the code), passing as input our WiFiClient object, which will be used under the hood to establish the protocol handshake.
This method call will return a Boolean value indicating if the handshake process was successfully performed, and thus we should also check for this value before proceeding with the actual communication with the client.
if (client.connected() && webSocketServer.handshake(client)) {
   // Communication with the client
Since we are going to develop a simple websocket echo server, we will need a data buffer to first receive the data from the client. As we will see next, the methods to use work with strings, which will be the data type of our buffer.
String data;
Since the client may disconnect at any time, we will now do a while loop which will keep executing while the client is connected.
Between each iteration of the loop, we need to add a small delay. This is of extreme importance because otherwise we will stop receiving data from the client after the first few bytes.
The code so far for our conditional block can be seen below.
    String data;
    while (client.connected()) {
       // Handle communication
       delay(10); // Delay needed for receiving the data correctly
Now, inside our loop, we will receive the data by calling the getData method on the webSocketServer object. This method receive no arguments and returns a String as output, which we will assign to our previously declared data buffer.
data = webSocketServer.getData();
After receiving the data, we will print it to the serial port and then echo it back to the client.
We send data to the client with a call to the sendData method of the WebSocketServer object. This method receives as input a String with the data to send to the client and returns void.
Since the client may have sent no data, we perform the previous calls inside a conditional block where we check for the length of our data buffer. So, the length should be greater than 0 for us to send the data back to the client.
if (data.length() > 0) {
   Serial.println(data);
   webSocketServer.sendData(data);
You can check the complete Arduino loop function below. Note that we added an extra print for when the client disconnects from the server. This happens when the loop where we check if the client is connected ends.
void loop() {
    String data;
   Serial.println("The client disconnected");
   delay(100);
  delay(100);
The final Arduino code
The final code Arduino can be seen below. You can simply copy and paste it to your Arduino environment. Don’t forget to put your WiFi network credentials on the global variables.
#include <WiFi.h>
void setup() {
    delay(1000);
  server.begin();
  delay(100);
void loop() {
    String data;
   delay(100);
  delay(100);
Testing the code
To test the code, first compile it and upload it to your ESP32 board using the Arduino IDE. Then, open the serial monitor with the baud rate defined on the Serial.Begin function.
Upon connecting to the WiFi network, the local IP of the ESP32 will be printed to the console. That is the IP you should use on the connect method, on the Python program.
Then, after putting the correct IP in the Python program and with the ESP32 connected, simply run the Python program. You should get the messages sent to the ESP32 echoed back and printed to the Python console, as shown in figure 1.
Figure 1 – Messages sent from the Python client echoed back.
If you go back to the Arduino IDE serial monitor, you should see the same messages getting printed, as shown in figure 2.
Figure 2 – Messages received by the ESP32.
Upon finishing sending all the messages, the Python client should disconnect. That should be detected on our Arduino loop that is checking for the connection and thus a message indicating that the client disconnected gets printed, as shown in figure 3.
Figure 3 – Client disconnected.
NOTE: This esp32 tutorial is written by Nuno Santos who is an kindly Electronics and Computers Engineer. live in Lisbon, Portugal. you could check the original article here.
He had written many useful tutorials and projects about ESP32, ESP8266, If you are interested, you could check his blog to know more.
