NEWS
Top 5 Best Selling Robot and Motor Sales
DFRobot Nov 20 2017 259850
What’s the benefit of using Robotics Platform ?
The biggest advantage of using robotics platform is on its “Applicability”. For the beginners, coding itself sounds super complicated yet difficult. However, if you turn it into a fun and playable project, learning coding wouldn’t be a matter at all. And you are be able to realize it by adding various sensors, servos, turntables and controllers with Robot platforms.
What’s Your Favorite Bonita Robot?
We offer a great deals on top 5 best selling robotics and motors within DFRobot. We prepared different product lines covering up the Primary school students to Maker pros.
During 18th-20th of each month(GMT +8), you are able to enjoy the special price that we offer.
Jun Robot Day Sales Products
DF Metal Geared 15Kg Standard Servo 270° (DSS-M15S)
Original Price
$14.9
Discount price
$11.9
DSS-M15S is a heavy-duty metal gear standard servo with 270°wide angle, high torque power, improved stability and durability.
This tough 270°servo is able to take in 6V and deliver a strong torque power of over 15Kg. It is tested with high load capacity for over 12 hours long. Result shows that this DSS-M15S servo demonstrates a maximum torque of 18Kg without much vibration or heat.
In addition, we enclose carefully selected steering parts, including an aluminum alloy wheel and a long bracket, to enhance servo performance.
More details and display videos about DF Metal Geared 15Kg Standard Servo 270° (DSS-M15S)
Goteck micro metal gear servo (2.5kg)
Original Price
$6.9
Discount price
$5.9
This is a metal gear servo(2.5kg) from Goteck. It's very small, lightweight, and powerful! Metal gear for longer wear life and extra strength in demanding applications. Perfect for use in medium-sized electric airplanes,helicopters or mini Robots.
More details about Goteck micro metal gear servo (2.5kg).
MiniQ 4WD Cross Country Arduino Mobile Robot
Original Price
$99
Discount price
$59
4WD MiniQ mobile platform is especially designed for education/learning purposes. It comes fully assembled and all your need is a PC with Arduino IDE and 4xAA battery. This alternative version of MiniQ 4WD robot provides higher ground clearance (25mm instead of 9mm), bigger approach angle and improved off-road capability in complex terrains. The mobile robot comes with Arduino Leonardo controller (ATmega32u4) and also integrates modules such as RGB LED, photosensitive diode, infrared trasmitters, infrared receivers, light sensors, additional buttons and buzzer.
Along with this upgraded MiniQ 4WD kit, we offer 8 lessons for beginners, from entry-level to line-following, obstacle avoidance, and remote control. Users can easily grasp through the tutorial. All codings and tutorials are open and free to download.
More details about MiniQ 4WD Cross Country Arduino Mobile Robot.
Cherokey: A 4WD Arduino Basic Robot Building Kit
Original Price
$109
Discount price
$89
The Cherokey 4WD Basic Arduino Robot Kit is a perfect wheeled robot platform to build  your own robot and to get started with Arduino Robot. With just a few simple steps of assembling the hardware and tuning the software, and you'll learn all about Arduino, robotics, sensors, bluetooth communication — as well as obstacle avoidance and remote control. You can also take it further with your own code to take advantage of the ultrasonic sensor, Romeo (All-in-one Bluetooth Microcontroller), IR sensors and LEDs.
Thanks to Romeo BLE, this kit can now be played with APP(IOS). Simply download the APP (GoBLE) and enjoy controlling from you IOS device!
More details about Cherokey: A 4WD Arduino Basic Robot Building Kit.
Turtle: 2WD Arduino Mobile Robot Platform
Original Price
$34.9
Discount price
$28.9
This DFRobot mobile robot platform is widely used as self-developed control chasis for Arduino platforms and other control boards. This kit features the following: two differential drives, near zero turning radius, high-strength aluminum alloy body material, motors and a flexible rubber wheel makes it suitable for indoor flat road surface and flat-platform robot completitions. The top layer includes a standard servo socket and the three optional sensor holder. This three sensor holder fits with our adjustable IR range sensor. The servo can be used for a simple rotation platform, a two degrees of freedom camera holder or even a robotic arm.
More details about Turtle: 2WD Arduino Mobile Robot Platform.
