TUTORIALS ESP32
ESP32 Arduino Tutorial HTTP server: Getting query parameters
DFRobot Dec 26 2017 264003
The objective of this ESP32 Arduino Tutorial is to explain how to obtain the query parameters from an HTTP request sent to a webserver running on the Arduino core, on the ESP32. The tests of this ESP32 tutorial were performed using a DFRobot’s ESP-WROOM-32 device integrated in a ESP32 development board.
The objective of this post is to explain how to obtain the query parameters from an HTTP request sent to a webserver running on the Arduino core, on the ESP32.
For an introduction to the HTTP asynchronous webserver on the ESP32, please consult this previous post.
The tests of this ESP32 tutorial were performed using a DFRobot’s ESP-WROOM-32 device integrated in a ESP32 FireBeetle board.
The Arduino code
We will start the Arduino code by the needed library includes, which will allow to set the HTTP server and to connect the ESP32 to a WiFi network. We will also declare two global variables to hold the credentials for the Wireless Network to which we are going to connect the ESP32.
To finalize the declaration of global variables, we will need an instance of class AsyncWebServer, which receives as input of the constructor the port where the server will be listening for incoming requests.
#include <WiFi.h> #include <FS.h> #include <AsyncTCP.h> #include <ESPAsyncWebServer.h> const char* ssid = "yourNetworkName"; const char* password =  "yourNetworkPass"; AsyncWebServer server(80);
Moving on to the setup function, we will start by opening a serial connection, so we can later output the results of the program, more precisely, the query parameters we are going to receive on the request.
After that, we are going to connect the ESP32 to the WiFi network, using the previously declared credentials. Note that at the end, after the connection is established, we print the IP of the ESP32 on the network, which will later be needed to connect to it.
Serial.begin(115200); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) {    delay(1000);    Serial.println("Connecting to WiFi.."); } Serial.println(WiFi.localIP());
Now we will setup a route on our server by binding it to a handling function. Inside that handling function, we will access the query parameters sent by the client.
We will use the index route (“/”) and specify that we will only receive HTTP GET requests on our route. Note that we will declare the handling function as a lambda function.
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){ // Handling function });
Inside the handling function, we will first check how many parameters were received. We can obtain this value by calling the params method on the request object, to which we receive a pointer as input of the handling function.
This method receives no arguments and, as said, will return the number of parameters received in the request.
int paramsNr = request->params(); Serial.println(paramsNr);
To obtain the actual parameters, we can use the getParam method of the same request object. This method receives as input the index (from 0 to number of parameters minus 1) of the parameter we want to obtain and returns a pointer to an object of class AsyncWebParameter, which contains the information about the parameter.
Since we already know the number of parameters from the previous call, we can do a for loop to obtain all the parameters.
We can obtain the name and the value of each parameter by calling the name and value methods on the AsyncWebParameter object, respectively.
Remember that we have a pointer to the object and not the actual object, so we need to use the -> operator to access the methods.
for(int i=0;i<paramsNr;i++){     AsyncWebParameter* p = request->getParam(i);     Serial.print("Param name: ");     Serial.println(p->name());     Serial.print("Param value: ");     Serial.println(p->value());     Serial.println("------"); }
Still inside the handling function, we will return the response to the client with a call to the send method on the request object. We will return a simple “Message received” string and a HTTP OK status.
request->send(200, "text/plain", "message received");
To finalize the Arduino setup function, we call the begin method on the global server object, to get the server started. The final complete source code can be seen below.
#include <WiFi.h> #include <FS.h> #include <AsyncTCP.h> #include <ESPAsyncWebServer.h>   const char* ssid = "yourNetworkName"; const char* password =  "yourNetworkPass";   AsyncWebServer server(80);   void setup(){  Serial.begin(115200);    WiFi.begin(ssid, password);    while (WiFi.status() != WL_CONNECTED) {    delay(1000);    Serial.println("Connecting to WiFi..");  }    Serial.println(WiFi.localIP());    server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){    int paramsNr = request->params();    Serial.println(paramsNr);    for(int i=0;i<paramsNr;i++){                AsyncWebParameter* p = request->getParam(i);        Serial.print("Param name: ");        Serial.println(p->name());        Serial.print("Param value: ");        Serial.println(p->value());        Serial.println("------");    }        request->send(200, "text/plain", "message received");  });    server.begin(); }   void loop(){}
Testing the code
To test the code, compile it and upload it to your ESP32 using the Arduino IDE. Then open the serial monitor and after the connection to the WiFi network finishes, use the IP that gets printed to send a GET request to the server from a web browser of your choice.
Since we want to test the query parameters, we will add some to our request. To do so, simply type the following on your browser’s address bar, changing {yourEspIp} by the IP printed to the serial monitor.
http://{yourEspIp}/?param1=10¶m2=hello
After sending the request, you should get an output similar to figure 1, which shows the string we defined being returned. The query parameters are highlighted in the image.
Figure 1 – Sending a HTTP GET request to the ESP32 webserver with query parameters.
If you go back to the Arduino Serial monitor, you should have an output like figure 2, which shows the number of parameters, their names and their values getting printed to the console. Note that they match the ones sent from the web browser.
Figure 2 – Obtaining the query parameters of the HTTP request.
