REVIEWS Raspberry Pi 2018 Raspberry Pi 3 B+ Review
Mar 27 2018 260604
In the two years since the current Raspberry Pi Model B, raspberry pi 3 b+ talked about their intention to do one more hardware revision to incorporate the numerous small improvements people have been asking for. This isn’t a “Raspberry Pi 2”, but rather the final evolution of the original Raspberry Pi.
At 14/3/2018, the latest version of Raspberry Pi is finally released what we’re calling the Raspberry Pi 3 Model B+.
Let's watch the raspberry pi module b+ video by raspberry pi official youtube together
First Look at the Raspberry Pi 3 B Plus
Raspberry PI Computer | Tutorial | Raspberry PI 3 Model B+
Make Mini PC using Raspberry Pi 3 and 7'' HDMI Display
A BRAND-NEW PI FOR π DAY
Introducing the Raspberry Pi 3 Model B+
The Raspberry Pi Model B+ is built around BCM2837B0, an updated version of the 64-bit Broadcom application processor used in Raspberry Pi 3B, which incorporates power integrity optimisations, and a heat spreader (that’s the shiny metal bit you can see in the photos). Together these allow us to reach higher clock frequencies (or to run at lower voltages to reduce power consumption), and to more accurately monitor and control the temperature of the chip.
Dual-band wireless LAN and Bluetooth are provided by the Cypress CYW43455 “combo” chip, connected to a Proant PCB antenna similar to the one used on Raspberry Pi Zero W. Compared to its predecessor, Raspberry Pi 3B+ delivers somewhat better performance in the 2.4GHz band, and far better performance in the 5GHz band, as demonstrated by these iperf results from LibreELEC developer Milhouse.
Some raspberry pi lovers had got a Model B+, they had played with it for a while. let's see what they think of rasbperry pi 3 plus:
Second: New Raspberry Pi 3 B+ (2018) Review and Speed Tests by Estefannie Explains It All
Three: Raspberry Pi 3 B+ - New Pi with New Features (2018) by TechWizTime
Four: Raspberry Pi 3 B+: Should you upgrade? // Review by MickMake
Five: Raspberry Pi 3 Model B+ 2018 Review and NEW GAMES!! by Simply Austin
Six: Raspberry Pi 3 B+ Review with Overclock by Novaspirit Tech
Seven: Raspberry Pi 3 B+ Review - Faster CPU, Faster WiFi & More by Make:
Eight: NEW Raspberry Pi 3 B+ - Quad-Core 1.4GHz and Gigabit Ethernet! by TheRaspberryPiGuy
Nine: Raspberry Pi Model 3 B+ vs Rasberry Pi 3 Model B by pi-top TEAM
Ten: First look at the Raspberry Pi Model B+ review by Geek Gurl Diaries
Have you got the raspberry pi b+ now? what do you think of it? welcome to comment after this blog and discuss with other makers, thanks for reading!
