TUTORIALS ESP32
ESP32 Arduino Tutorial: Getting available messages and free spaces of FreeRTOS queue
DFRobot Apr 24 2018 261161
The objective of this ESP32 Arduino Tutorial is to explain how to check how many messages are available on a FreeRTOS queue, without consuming them. We will also check how to use the API to get how many free spaces are still available on the same queue. The tests of this ESP32 tutorial were performed using a DFRobot’s ESP32 device integrated in a ESP32 development board.
We will perform the tests over a queue of integers, jut for exemplification. All the queue handling code will be done on the main loop, for us to focus on the relevant APIs.
The tests of this ESP32 tutorial were performed using a DFRobot’s ESP32 module device integrated in a ESP32 development board.
The code
We will start by declaring a global queue handle variable, so it can be shared between the Arduino setup function and main loop. This will be used to store the result of the queue creation API call.
Next we will create the queue on the setup function. We will create it with 5 elements of type int. Please consult this previous post for more information about creating queues.
We will also start a serial connection on the setup function for later printing the results.
QueueHandle_t queue;
void setup() {
  Serial.begin(115200);
  queue = xQueueCreate( 5, sizeof( int ) );
  if(queue == NULL){
    Serial.println("Error creating the queue");
Now, in the Arduino main loop function, we will insert 5 elements in the queue, inside a for loop. Thus the queue should become full. You can check more about inserting elements in a FreeRTOS queue here.
for(int i = 0; i<5; i++){
    xQueueSend(queue, &i, 0);
Now, in another loop, we will use the APIs to check both how many elements are on the queue and how many empty spaces are available.
So, to check how many messages are available in the queue, we call the uxQueueMessagesWaiting function and simply pass as input the queue handle. The function should return the number of messages available.
Similarly, to get the number of empty spaces, we call the uxQueueSpacesAvailable function and also pass as input the same queue handle. It should return the number of empty spaces.
int messagesWaiting = uxQueueMessagesWaiting(queue);
int emptySpaces = uxQueueSpacesAvailable(queue);
Before the previous calls, we will consume an item from the queue, so we see the results from the previous invocations changing. For more on consuming queue items, please check here.
The final source code can be seen bellow. It already includes the consumption of the queue items, some additional prints to the serial port and also a null check to confirm if the queue was created or not, before using it in the main loop.
void setup() {
  if(queue == NULL){
void loop() {
  if(queue == NULL)return;
  Serial.println("##########New iteration#########");
  int element;
    Serial.println("---------------------");
    xQueueReceive(queue, &element, 0);
    Serial.print("Messages waiting: ");
    Serial.println(messagesWaiting);
    Serial.print("Empty spaces: ");
    Serial.println(emptySpaces);
    Serial.print("Element: ");
    Serial.println(element);
  Serial.println();
  delay(1000);
Testing the code
To test the code, simply compile it and upload it to your ESP32. Then, open the Arduino IDE serial monitor. As shown below in figure 1, the number of messages and spaces available are both printed and change accordingly as we consume queue items.
Note that the first iteration output has 4 messages available and 1 empty space since we invoke the APIs after consuming the first item.
Figure 1 – Output of the execution of the program.
