Xbee problem
zul88 2011-09-24 05:43:28 5163 Views1 Replies hello..
i only got this item below..
XBee 1mW Wire Antenna x 2
XBee Explorer Dongle x 1
Roboduino Romeo x 1
Xbee Shield For Arduino x 1
i got a question on how to control my 4WD via Xbee wireless?
is it posible?
Roboduino Romeo x 1
is it posible?
2011-09-27 18:40:58 Hi Zul,
You can use the serial monitor to control the robot from your PC. just make sure the Xbee's are talking to each other, then connect to the USB adapter Xbee, and it will send the commands to the ROMEO Xbee
Good luck!
Hector
Hector
Good luck!
Hector
Hector
