xbee bluetooth
userHead Account cancelled 2012-03-10 22:24:14 4541 Views1 Replies
hey, i just purchase the xbee bluetooth and i have been looking at different tutorial; iam kind of confuse, do i need to buy a bluetooth modem to connect with the bluetooth module i purchase or i can directly connect the bluetooth module to arduino and have a wirelless connection my pc to that xbee bluetooth?
and by the way there is no schematic of how to really connect that xbee bluetooth to arduino
2012-03-12 19:43:03 Hi Valerynoah,
Your computer needs to have a bluetooth radio as well. If its a laptop it might already have one integrated. otherwise you can just purchase a USB bluetooth dongle. We sell one in the store.
How are you trying to connect it to your arduino? We recommend using the IO Expansion shield which comes with a header for Xbee radios. You could optionally connect it with wires, but this might result in faulty connections and cause some problems.
If you look at the bluetooth bee you can see a pin out diagram. Indicating what each pin is.
You basically only need 4 pins connected to the arduino.
GND
3.3V
Tx
Rx
userHeadPic Hector
