Re: Detection Frequency
userHead Lauren 2012-11-23 21:31:55 6921 Views6 Replies
The resolution of the encoder depends on the encoder disk. According to my experience, the arduino could detect about 50-70 pps from this encoder when the 4WD running on the max speed!
Regards,
Lauren
2012-11-28 01:12:36 ;D
userHeadPic nhatnam06dt1
2012-11-28 00:17:50 Oh, yes, you're correct.
I mean the period is 20ms.......=-=" Haha....
userHeadPic Lauren
2012-11-27 23:57:09 Thank Lauren!
But I don't understand.
50 pulse per second -> f= 20Hz???
Because: 50 pulse per second -> 1 pulse need 1/50 second -> f(detection frequency)=50Hz???
Best Regards,
2012-11-26 22:09:22 Oh....
Obviously, this product is not good enough for your application. This product is a simple and cheap solution for 4WD speed control.
1. 50-70 pps -> 50 pulse per second -> just 20Hz frequency.
2. Right. 20 PPR means 20 pulse per one ring.
The ir sensor of this product is fit with your requirement. But the encoder wheel is a low resolution one.I think this type of encoder wheel maybe useful.
[url=http://www.google.com/imgres?start=113&num=10&hl=en&newwindow=1&tbo=d&authuser=0&biw=1502&bih=773&tbm=isch&tbnid=mZWvZntMwZGNLM:&imgrefurl=http://www.embedded.arch.ethz.ch/Projects/EmbossingPrinter&docid=S1d2XMTnVsSuKM&imgurl=http://www.embedded.arch.ethz.ch/uploads/Projects/EmbossingPrinter/IMG_3221_700px.jpg&w=700&h=525&ei=hgazUIjkIMG1iwLy54CwAQ&zoom=1&iact=hc&vpx=192&vpy=290&dur=77&hovh=194&hovw=259&tx=158&ty=77&sig=102631316387023284600&page=4&tbnh=143&tbnw=200&ndsp=40&ved=1t:429,r:14,s:100,i:46]http://www.google.com/imgres?start=113&num=10&hl=en&newwindow=1&tbo=d&authuser=0&biw=1502&bih=773&tbm=isch&tbnid=mZWvZntMwZGNLM:&imgrefurl=http://www.embedded.arch.ethz.ch/Projects/EmbossingPrinter&docid=S1d2XMTnVsSuKM&imgurl=http://www.embedded.arch.ethz.ch/uploads/Projects/EmbossingPrinter/IMG_3221_700px.jpg&w=700&h=525&ei=hgazUIjkIMG1iwLy54CwAQ&zoom=1&iact=hc&vpx=192&vpy=290&dur=77&hovh=194&hovw=259&tx=158&ty=77&sig=102631316387023284600&page=4&tbnh=143&tbnw=200&ndsp=40&ved=1t:429,r:14,s:100,i:46[/url]
userHeadPic Lauren
2012-11-24 07:25:23 Hi!
I have a question about Wheel Encoder for DFRobot 3PA and 4WD Rovers (Product Code: SEN0038).
How much is detection frequency of it?
Thank in advance!
2012-11-23 23:11:07 Thank!
As you say: 50-70pps (pulse per second) -> dectection frequency = 50-70Hz. Is it right?
But I need to know exactly detection frequency. Because my application, I need to 2kHz frequency.
Resolution: 20ppr, mean 20 pulse per one ring (both HIGH and LOW)
Best Regard
