Is SEN0019 modulated ?
Sababo 2013-06-07 00:51:09 5978 Views2 Replies Hi,
I would like to add some sensors to my robot and SEN0019 is interesting. But is it modulated ?
If you put 2 SEN0019 face to face, do they work correctly ?
Thanks a lot for your help.
2013-06-07 23:28:48 Hi Phoebe.
I know about the small knob to adjust the distance.
Imagine they is two robots (A and B) using SEN0019 to avoid obstacle.
"A" is running to "B" and "B" is running to "A". Will the sensor work properly is this case or they will disturbed each other ?
Cheers,
If their going to meet (face to face)
Sababo
Cheers,
Sababo 2013-06-07 18:53:42 Hi
The distance can be adjust by the small knob on the back of the sensor depend on your need. What you mean by using two sensors face to face? If you just want detect the distance, i think one is enough.
Best
Phoebe
Best
Phoebe
