test motor speed with Arduino and IR switch sensor
Leff 2015-07-16 02:37:48 1898 Views0 Replies
Code: Select allunsigned int Speed = 0;
int IRsensor = 2;
Serial.begin(9600);
Serial.println("Start!");
pinMode(IRsensor,INPUT);
void loop(){
static unsigned long timepoint = millis();
static unsigned long timepoint1 = millis();
static byte count = 0;
if(millis()-timepoint > 2)
if(digitalRead(IRsensor)) count = 0;
if( (count<30) && (++count==10) )
Speed++;
if(millis()-timepoint1 > 10000){
Speed = Speed * 6;
Serial.print("Speed is: ");
Serial.println(Speed);
Speed = 0;
