Bluno Bluetooth Protocol descriptions
userHead VW 2014-03-16 20:27:12 22029 Views17 Replies
Any chance to have a description of peripheral, services and characteristics used, without using the framework to make an app?
I'd like to use the TechBasic to prototype for Bluno, so I need to know how to connect using the the UUIDs.
Thanks in advance
2014-11-13 11:24:49 For Grey and/or VW
VW, you mention a techBasic demo in one of your posts. Is that available to share?
Toby
userHeadPic toby
Toby
userHeadPic toby
2014-10-31 02:10:27 Hello Paul.
I am not sure whether "BLE Scanner" could communicate with the Bluno.
I remember their protocol are different.
But if you only need data communication, our app should be enough.
https://raw.githubusercontent.com/DFRob ... icDemo.apk
userHeadPic Grey.CC
userHeadPic Grey.CC
2014-10-29 10:08:41 The wiki says
"for the developer, recommend to custom or choose the protocol according to the product features or the application."
How is this done?
BTW. I got an android app called "BLE Scanner" that finds all the UUIDs.  Wend to dfb0/dfb1 which shows support for Read, Notification and Write.  This looked encouraging.
As this app implements the standard BLE protocol I thought it would be useful to see if the bluno can operate that way.
I put in a sketch that just loops around sending some fixed (non-zero) data.
On the scanner, a read comes back with 0 and Notification comes back with a load of zeros.
It strikes me that I need to configure something for the data I am sending to be visible in this way.
Any comments?
Paul
userHeadPic paul_tanner
How is this done?
Any comments?
Paul
2014-03-21 18:54:49 Except your DEMO~
userHeadPic Grey.CC
userHeadPic Grey.CC
2014-03-21 09:43:06 Thank you. These have helped. If anyone is interested, I wam willing to share my techBasic demo when I get it finished.
- VW
userHeadPic VW
- VW
userHeadPic VW
2014-03-20 21:53:24 Hello VW,
DFB1  Transparent transmission, Master: write; client:notify
DFB2  AT command?>=V1.7?The module could works in both AT mode and NORM mode. Master: write; client:notify
DFB3 DFB4 DFB5?obligate (have not used)
Hope it will be useful.
userHeadPic Grey.CC
userHeadPic Grey.CC
2014-03-18 18:51:15 Yeah, I'd like to see a real BLE API as well. PlainProtocol is fine for some things, but it don't work with BLE standards.
Here's a bunch of info, but no idea how we can access from the Bluno Arduino API.
Code: Select all
attr handle: 0x0001, end grp handle: 0x000b uuid: 00001800-0000-1000-8000-00805f9b34fb
attr handle: 0x000c, end grp handle: 0x000f uuid: 00001801-0000-1000-8000-00805f9b34fb
attr handle: 0x0010, end grp handle: 0x0022 uuid: 0000180a-0000-1000-8000-00805f9b34fb
attr handle: 0x0023, end grp handle: 0xffff uuid: 0000dfb0-0000-1000-8000-00805f9b34fb
    public static final String SerialPortUUID="0000dfb1-0000-1000-8000-00805f9b34fb";
    public static final String CommandUUID="0000dfb2-0000-1000-8000-00805f9b34fb";
    public static final String ModelNumberStringUUID="00002a24-0000-1000-8000-00805f9b34fb";
SerialPort String Notification Handle
 char-read-uuid dfb1
handle: 0x0025   value: 3c
Command String
char-read-uuid dfb2
handle: 0x0028   value: 02
Model Number String
 char-read-uuid 2a24
 handle: 0x0014  value: 44 46 20 42 4c 75 6e 6f 00 == DF BLuno\0
> characteristics
handle: 0x0002, char properties: 0x02, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, char properties: 0x0a, char value handle: 0x0007, uuid: 00002a02-0000-1000-8000-00805f9b34fb
handle: 0x0008, char properties: 0x0a, char value handle: 0x0009, uuid: 00002a03-0000-1000-8000-00805f9b34fb
handle: 0x000a, char properties: 0x02, char value handle: 0x000b, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x20, char value handle: 0x000e, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x0011, char properties: 0x02, char value handle: 0x0012, uuid: 00002a23-0000-1000-8000-00805f9b34fb
handle: 0x0013, char properties: 0x02, char value handle: 0x0014, uuid: 00002a24-0000-1000-8000-00805f9b34fb
handle: 0x0015, char properties: 0x02, char value handle: 0x0016, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x0017, char properties: 0x02, char value handle: 0x0018, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x0019, char properties: 0x02, char value handle: 0x001a, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x001b, char properties: 0x02, char value handle: 0x001c, uuid: 00002a28-0000-1000-8000-00805f9b34fb
handle: 0x001d, char properties: 0x02, char value handle: 0x001e, uuid: 00002a29-0000-1000-8000-00805f9b34fb
handle: 0x001f, char properties: 0x02, char value handle: 0x0020, uuid: 00002a2a-0000-1000-8000-00805f9b34fb
handle: 0x0021, char properties: 0x02, char value handle: 0x0022, uuid: 00002a50-0000-1000-8000-00805f9b34fb
handle: 0x0024, char properties: 0x1e, char value handle: 0x0025, uuid: 0000dfb1-0000-1000-8000-00805f9b34fb
handle: 0x0027, char properties: 0x1e, char value handle: 0x0028, uuid: 0000dfb2-0000-1000-8000-00805f9b34fb
handle: 0x002a, char properties: 0x18, char value handle: 0x002b, uuid: 0000dfb3-0000-1000-8000-00805f9b34fb
handle: 0x002d, char properties: 0x10, char value handle: 0x002e, uuid: 0000dfb4-0000-1000-8000-00805f9b34fb
handle: 0x0031, char properties: 0x02, char value handle: 0x0032, uuid: 0000dfb5-0000-1000-8000-00805f9b34fb
 ** GAP **
handle: 0x0001, uuid: 2800      - 00 18                         1800 means Generic Access Service
handle: 0x0002, uuid:  2803     - 02 03 00 00 2a                02,0003,2a00 (R,hnd=3,type=device name)
handle: 0x0003, uuid: 2a00      - (blank)
handle: 0x0004, uuid:  2803     - 02 05 00 01 2a                02,0005,2a01 (R,hnd=5,type=appearance)
handle: 0x0005, uuid: 2a01      - 00 00
handle: 0x0006, uuid:  2803     - 0a 07 00 02 2a                0a,0007,2a02 (WR,hnd=7,type=Peripheral privacy flag)
handle: 0x0007, uuid: 2a02      - 00
handle: 0x0008, uuid:  2803     - 0a 09 00 03 2a                0a,0009,2a03 (WR,hnd=9,type=Reconnection Address)
handle: 0x0009, uuid: 2a03      - 00 00 00 00 00 00
handle: 0x000a, uuid:  2803     - 02 0b 00 04 2a                02,000b,2a04 (R,hnd=b,type=peripheral preferred connection parameters)
handle: 0x000b, uuid: 2a04      - 50 00 a0 00 00 00 e8 03       0050 00a0 0000 03e8 interval=100-200ms latency=0ms timeout=1000ms
 ** GATT **
handle: 0x000c, uuid: 2800      - 01 18                         1801 means Generic Attribute Service
handle: 0x000d, uuid:  2803     - 20 0e 00 05 2a                02,000e,2a05 (R,hnd=e,type=service changed)
handle: 0x000e, uuid: 2a05      - Attribute can't be read
handle: 0x000f, uuid: 2902      - 00 00
 ** Device Info **
handle: 0x0010, uuid: 2800      - 0a 18                         180a means Device Information
handle: 0x0011, uuid:  2803     - 02 12 00 23 2a                02,0012,2a23 (R,hnd=12,type=System ID)
handle: 0x0012, uuid: 2a23      - 62 c5 27 00 00 af 59 90
handle: 0x0013, uuid:  2803     - 02 14 00 24 2a                02,0014,2a24 (R,hnd=14,type=Model Number String)
handle: 0x0014, uuid: 2a24      - 44 46 20 42 4c 75 6e 6f 00                    (DF BLuno)
handle: 0x0015, uuid:  2803     - 02 16 00 25 2a                02,0016,2a25 (R,hnd=16,Serial Number String)
handle: 0x0016, uuid: 2a25      - 30 31 32 33 34 35 36 37 38 39 00              (0123456789)
handle: 0x0017, uuid:  2803     - 02 18 00 26 2a                02,0018,2a26 (R,hnd=18,Firmware Revision String)
handle: 0x0018, uuid: 2a26      - 46 57 20 56 31 2e 30 00                       (FW V1.0)
handle: 0x0019, uuid:  2803     - 02 1a 00 27 2a                02,001a,2a27 (R,hnd=1a,type=Hardware Revision String)
handle: 0x001a, uuid: 2a27      - 48 57 20 56 31 2e 30 00                       (HW V1.0)
handle: 0x001b, uuid:  2803     - 02 1c 00 28 2a                02,001c,2a28 (R,hnd=1c,type=Software Revision Strin)
handle: 0x001c, uuid: 2a28      - 53 57 20 56 31 2e 30 00                       (SW V1.0)
handle: 0x001d, uuid:  2803     - 02 1e 00 29 2a                02,001e,2a29 (R,hnd=1e,type=Mfg Name String
handle: 0x001e, uuid: 2a29      - 44 46 52 6f 62 6f 74 00                       (DFRobot)
handle: 0x001f, uuid:  2803     - 02 20 00 2a 2a                02,0020,2a2a (R,hnd=20,type=IEEE Cert list)
handle: 0x0020, uuid: 2a2a      - fe 00 65 78 70 65 72 69 6d 65 6e 74 61 6c     (ffe0 experimental)
handle: 0x0021, uuid:  2803     - 02 22 00 50 2a                02,0022,2a50 (R,hnd=22,type=PnP ID)
handle: 0x0022, uuid: 2a50      - 01 0d 00 00 00 10 01
 ** BLUNO SPECIFIC **
handle: 0x0023, uuid: 2800      - b0 df                         dfb0
handle: 0x0024, uuid:  2803     - 1e 25 00 b1 df                1e,0025,dfb1 (NWWnRR,hnd=25,type= ??)
handle: 0x0025, uuid: dfb1      - 01                    receivedCommand ()
handle: 0x0026, uuid: 2901      - 53 65 72 69 61 6c 20 52 63 76                 (Serial Rcv)
handle: 0x0027, uuid:  2803     - 1e 28 00 b2 df                1e,0028,dfb2 (NWWnRR,hnd=28,type= ??)
handle: 0x0028, uuid: dfb2      - 02                    DTR Port ???
handle: 0x0029, uuid: 2901      - 43 68 61 72 61 63 74 65 72 69 73 74 69 63 20 32 (Characteristic 2)
handle: 0x002a, uuid:  2803     - 18 2b 00 b3 df                18,002b,dfb3 (NW,hnd=2b,type= ??)
handle: 0x002b, uuid: dfb3      - Attribute can't be read  Open USB??? receivedCommand gives (KeyPress:text)
handle: 0x002c, uuid: 2901      - 43 68 61 72 61 63 74 65 72 69 73 74 69 63 20 33 (Characteristic 3)
handle: 0x002d, uuid:  2803     - 10 2e 00 b4 df                10,002e,dfb4 (N,hnd=2e,type= ??)
handle: 0x002e, uuid: dfb4      - Attribute can't be read
handle: 0x002f, uuid: 2902      - 00 00
handle: 0x0030, uuid: 2901      - 43 68 61 72 61 63 74 65 72 69 73 74 69 63 20 34 (Characteristic 4)
handle: 0x0031, uuid:  2803     - 02 32 00 b5 df                02,0032,dfb5 (R,hnd=32,type= ??)
handle: 0x0032, uuid: dfb5      - Attribute requires authentication before read/write
handle: 0x0033, uuid: 2901      - 43 68 61 72 61 63 74 65 72 69 73 74 69 63 20 35 (Characteristic 5)
[/code/
userHeadPic tolson
Code: Select all
 char-read-uuid dfb1
Command String
char-read-uuid dfb2
Model Number String
 char-read-uuid 2a24
> characteristics
 ** GAP **
 ** GATT **
 ** Device Info **
[/code/
userHeadPic tolson
2014-03-18 15:28:36 These are the characteristics that I need info on.
Characteristics for Service DFB0
Characteristc DFB1 is this the serial port?? Is this how the ios app talks to the bluno?
Characteristc DFB2 ??? Command ?? What is it used for.
Characteristc DFB3
Characteristc DFB4
Characteristc DFB5
Any help would be appreciated. Anyone??
Thx.
userHeadPic VW
Characteristc DFB3
Characteristc DFB4
Characteristc DFB5
Thx.
userHeadPic VW
2014-03-16 20:27:12 Any chance to have a description of peripheral, services and characteristics used, without using the framework to make an app?
Thanks in advance
userHeadPic VW
