Nixie Module and Arduino - not enough power?
phinix_mike 2015-09-28 11:04:59 12356 Views5 Replies Hi there,
I've built a wee CPU temperature indicator using two Nixie Modules and Arduino, powered via USB cable.
However it looks like when using two nixie tubes/modules one of them is always dimmed, like not enough power. It changes sometimes and both light up strong, but randomly they go down a bit..
Is USB not giving enough power for two modules?
What should I do?
2016-11-04 22:17:50 Hi abdulrahman.alserkal,
As I know, there isnt a working voltage range, according to the schematic, there is a booster circuit on the module, the minimum input voltage should be 5v, but maximum voltage should be not too much bigger than 5 v. Since I dont have a module to do a test, I cant give you how much can be larger than 5V.
Wendy.Hu
Wendy.Hu 2016-10-18 22:21:29 Hi there, need some technical help as I could not find this anywhere online.
regarding the Nixie Module -Limited (Arduino Compatible) SKU:DFR0206, what is the maximum power input that I can provide? It says to provide 5V, but what is the maximum voltage I can connected to? Does it have a working voltage range?
thank you
thank you
abdulrahman.alserkal 2015-09-30 22:19:54
I am not sure about it. You can give it a try.
Leff
phinix_mike wrote:Yes, PSU molex power cable, using 5V
Leff 2015-09-29 21:59:39
Yes, both sides could be available for the power input/ output.
Inside the PC, computer you mean?
Leff
phinix_mike wrote:Does it mean that output connectors on module can be used to give power to it?
phinix_mike wrote:I thought I may need to give it more power, but how can I do it inside the PC?
Leff
