Help adding code to sample code for DTMF Shield *Pre order
userHead Account cancelled 2015-11-03 06:39:52 3313 Views1 Replies
I have a question before I buy the DTMF Shield
What I want to do is have the code "loop" until the DTMF Shield reads 8 DTMF tones
Then print them as a set, *not each individually as it reads them
Example:
If it read DTMF Tone 5
then DTMF Tone 4
then DTMF Tone 3
then DTMF tone 1
then DTMF tone 9
then DTMF tone 3
then DTMF tone 4
then DTMF tone 5
It would not have Serial.printed anything until it reached 8 "reads", but would print "54319345" all at once
I would use a "for I" with a "++" ??
here is the sample code
DTMF Arduino
Q1 12
Q2 11
Q3 10
Q4 9
STD 8
SPK2 3
SPK1 2
Q1~Q4 and STD are part of the DTMF demodulation interface. These pins are required for this board SPK pins are for an optional DTMF modulation from arduino. Which requires an alternative library for tone generation, read below for more details
Connection Diagram
For the Shield version, just stack it on an Arduino compatible device. If you are using the module, just wire the pins like the table above to your Arduino.
Sample Code
DTMF.cpp - Example code for DTMF library
Pin Diagram
DTMF Arduino
Q1 12
Q2 11
Q3 10
Q4 9
STD 8
SPK1 2
SPK2 3
#include "dtmf.h"
DTMF dtmf;
Serial.begin(9600);
// Play a default number with all possibilities
//dtmf.playDTMF();
// Read DTMF codes one by one and print it on Serial
int myDtmf;
myDtmf = dtmf.getDTMF();
if(myDtmf != -1) Serial.println(myDtmf);
delay(80); // to avoid getting repeated output.
2015-11-03 19:17:16 Helllo,
Sure it can be done, I remember there was a function could adhere words to a string, but I don't remember. Anyway, it could also be realise by setting an array. You could make a judge wether the num is 8, if not, store them in the array, if yes, print the array.
userHeadPic Leff
