interface arduino wifi shield v2.2 and visual basic
salem89 2014-03-29 02:18:27 7404 Views4 Replies Greeting everyone
I'm doing a project of controlling robot(left,right,backward and forward).using:
1. visual basic6 command to control robot
2. connection through arduino wifi shield v2.2
3.progarmming using arduino
I have set the AT command for wifi shield correctly and can work.
the robot should be controlled throughout Visual basic 6(GUI for controlling motion) using keyboard.
in Visual basic6 i used winsock over TCP/IP connection in order to connect to wifi shield and execute the motion.
currently, i stuck how to make interfacing between arduino and visual basic 6,
bellow all programming that i hv been done,hope i can get help.
2014-03-31 22:48:25 Hello Salem,
I am not familiar with VB, sorry.
But i guess you could test with Telnet first for the commands and the move them on your VB code.
Jose
Jose 2014-03-29 08:28:38 yes, that has been done
the main problem is with arduino wifi shield v2.2
need to transfer the command wireless,,
i have been set the AT command ,but i couldnt figure out how to translate that command to accept comming data from Visual basic 6,pls read the code and tell me if any correction
salem89
salem89 2014-03-29 02:20:35 you could try to send some data from VB to your arduino first. and check with software serial, or LED
Jose
Jose 2014-03-29 02:18:27 arduino sketch
//Standard PWM DC control
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
void stop(void) //Stop
digitalWrite(E1,LOW);
digitalWrite(E2,LOW);
void advance(char a,char b) //Move forward
analogWrite (E1,a); //PWM Speed Control
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
void back_off (char a,char b) //Move backward
analogWrite (E1,a);
digitalWrite(M1,LOW);
analogWrite (E2,b);
digitalWrite(M2,LOW);
void turn_L (char a,char b) //Turn Left
analogWrite (E1,a);
analogWrite (E2,b);
void turn_R (char a,char b) //Turn Right
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
Serial.begin(115200); //Set Baud Rate
Serial.println("Run keyboard control");
void loop(void)
if(Serial.available()){
char val = Serial.read();
if(val != -1)
switch(val)
case 'W'://Move Forward
advance (255,255); //move forward in max speed
break;
case 'S'://Move Backward
back_off (255,255); //move back in max speed
break;
case 'A'://Turn Left
turn_L (100,100);
break;
case 'D'://Turn Right
turn_R (100,100);
break;
visual basic 6
Option Explicit
Public direction As String
Public ttime As Integer
Public address As String
Public upstatus, downstatus, leftstatus, rightstatus, hornstatus As Integer
Public output As Integer
Private Sub call_timer_Timer()
Call motion("manual", upstatus + downstatus + rightstatus + leftstatus + hornstatus)
'Calls motion module. Lets it know manual driving and what value to output to the
'parallel port
End Sub
Private Sub Command1_Click()
If sock.State = sckClosed Then ' if the socket is closed
sock.RemoteHost = lbladdress.Text ' set server adress
sock.RemotePort = "1500" ' set server port
Label5.Caption = "Connected"
sock.Connect ' start connection attempt
Else ' if the socket is open
sock.Close ' close it
Label5.Caption = "Not Connected"
End If
End Sub
Private Sub Form_KeyDown(KeyCode As Integer, Shift As Integer)
'Detects if control keys are pressed
If KeyCode = vbKeyEscape Then End 'Exits
If KeyCode = vbKeyC Then Call Command1_Click
If KeyCode = vbKeyUp Or KeyCode = vbKeyW Then: cmd_up.BackColor = &HFF0000: cmd_up.Picture = cmd_up.DownPicture: upstatus = 6
'If up arrow is pressed or W then change pictures (make it blue) and change upstatus.
If KeyCode = vbKeyDown Or KeyCode = vbKeyS Then cmd_down.BackColor = &HFF0000: cmd_down.Picture = cmd_down.DownPicture: downstatus = 9
'If down arrow is pressed or S then change pictures (make it blue) and change downstatus.
If KeyCode = vbKeyLeft Or KeyCode = vbKeyA Then cmd_left.BackColor = &HFF0000: cmd_left.Picture = cmd_left.DownPicture: rightstatus = 5
'If left arrow is pressed or A then change pictures (make it blue) and change rightstatus.
If KeyCode = vbKeyRight Or KeyCode = vbKeyD Then cmd_right.BackColor = &HFF0000: cmd_right.Picture = cmd_right.DownPicture: leftstatus = 10
'If right arrow is pressed or D then change pictures (make it blue) and change leftstatus.
If KeyCode = vbKeyH Then hornstatus = 32
End Sub
Private Sub Form_KeyUp(KeyCode As Integer, Shift As Integer)
'Stops output to that direction when key is lifted.
'Changes pictures back to unactivated (none-blue).
If KeyCode = vbKeyUp Or KeyCode = vbKeyW Then cmd_up.BackColor = &HFFFFFF: cmd_up.Picture = cmd_up.DisabledPicture: upstatus = 0
If KeyCode = vbKeyDown Or KeyCode = vbKeyS Then cmd_down.BackColor = &HFFFFFF: cmd_down.Picture = cmd_down.DisabledPicture: downstatus = 0
If KeyCode = vbKeyLeft Or KeyCode = vbKeyA Then cmd_left.BackColor = &HFFFFFF: cmd_left.Picture = cmd_left.DisabledPicture: rightstatus = 0
If KeyCode = vbKeyRight Or KeyCode = vbKeyD Then cmd_right.BackColor = &HFFFFFF: cmd_right.Picture = cmd_right.DisabledPicture: leftstatus = 0
If KeyCode = vbKeyH Then hornstatus = 0
End Sub
Private Sub Form_Load()
Dim line As String
'Stores {Arrow with white} pic in .DisabledPicture for each button
cmd_up.DisabledPicture = cmd_up.Picture
cmd_down.DisabledPicture = cmd_down.Picture
cmd_left.DisabledPicture = cmd_left.Picture
cmd_right.DisabledPicture = cmd_right.Picture
'Following Opens Config.txt and collect Parallel Port Address and Refresh Rate
Open CurDir & "\config.txt" For Input As #1
Line Input #1, line
Line Input #1, line
address = line 'Sets parallel port address
lbladdress.Text = address 'displays address
call_timer.Interval = 5
End Sub
Private Sub sock_Close()
sock.Close ' has to be
End Sub
Private Sub sock_Error(ByVal Number As Integer, Description As String, ByVal Scode As Long, ByVal Source As String, ByVal HelpFile As String, ByVal HelpContext As Long, CancelDisplay As Boolean)
MsgBox "Socket Error " & Number & ": " & Description
sock.Close ' close the erraneous connection
End Sub
'Motion Executor
Sub motion(direction As String, ttime As Integer)
address = Form1.address
Select Case direction
Case 1 To 6
Case "manual"
'If manual driving, parallel port output required for direction has already
'been calculated, so output value passed to ttime
output = ttime
Case "FF"
output = 1
Case "BB"
output = 2
Case "RR"
output = 8
Case "LL"
output = 4
Case "SS"
output = 0
End Select
Rem vbOut address, output
'sock.SendData output & Chr(0)
If sock.State = sckConnected Then
If output = &HC Or output = &H1C Then output = output - 8
If output = &H3 Or output = &H13 Then output = output - 2
sock.SendData Chr(output + 1) & Chr(0)
Label5.Caption = Chr(output + 1) & Chr(0)
Else
Label5.Caption = "NOT sending data"
End If
End Sub
salem89
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
void loop(void)
if(val != -1)
switch(val)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
visual basic 6
Option Explicit
'parallel port
End Sub
End If
End Sub
End Sub
End Sub
Dim line As String
Line Input #1, line
Line Input #1, line
End Sub
End Sub
End Sub
'Motion Executor
Case 1 To 6
Case "manual"
output = ttime
Case "FF"
output = 1
Case "BB"
output = 2
Case "RR"
output = 8
Case "LL"
output = 4
Case "SS"
output = 0
End Select
Else
End If
End Sub
salem89
