Smart Servo Shield fro Arduino
msteven7 2016-01-09 13:39:27 3190 Views2 Replies HI, i recently bought one of these Shield, to run an AX12_A Dynamixel servo... i hooked it up to an 11.1 voltage source, with one servo connected and uploaded both libraries....but when i attempted to run the example code nothing happened....has anyone else had this problem and can suggest a solution to make this shield operational ?
2016-01-21 18:00:39 Hi msteven7,
The original code on wiki was not fully compatible with Dynamixel AX samrt servo, but it can run it at least, only when you change its working mode, it will became useless to control the servo. But there is a solution that RESET the module when you are going to change its workin mode.
By the way, I've update its sample code, it's working now. Have a try please!
https://www.dfrobot.com/wiki/index.php/D ... KU:DRI0027
Leff
# This Sample code is to test the Digital Servo Shield.
# Editor : Leff
# Date : 2016-1-19
# Ver : 1.1
# Product: Digital Servo Shield for Arduino
# Hardwares:
1. Arduino UNO
2. Digital Servo Shield for Arduino
3. Digital Servos( Compatible with AX-12,CDS55xx...etc)
4. Power supply:6.5 - 12V
# How to use:
If you don't know your Servo ID number, please
1. Open the serial monitor, and choose NewLine,115200
2. Send command:'d',when it's finished, please close the monitor and re-open it
3. Send the command according to the function //controlServo()//
#include <SPI.h>
#include <ServoCds55.h>
ServoCds55 myservo;
int servoNum = 1;
char inputCommand ; // a string to hold incoming data
boolean inputComplete = false;
void setup () {
Serial.begin (115200);
myservo.begin ();
void loop () {
serialEvent();
if (inputComplete) {
Serial.print("Your command is: "); Serial.println(inputCommand); Serial.println("");
controlServo(inputCommand);
// clear the command:
inputCommand = 0;
void serialEvent() {
while (Serial.available()) {
char inChar = (char)Serial.read();
if (inChar == '\n') {
inputComplete = true;
break;
inputCommand += inChar;
void controlServo(char val) {
switch (val) {
case 'p':
myservo.write(servoNum, 300); //ID:1 Pos:300 velocity:150
delay(3000);
myservo.write(servoNum, 0); //ID:1 Pos:0 velocity:150
break;
case 'v':
myservo.setVelocity(200);// set velocity to 100(range:0-300) in Servo mode
break;
case 'm':
myservo.rotate(servoNum, 150); // Anti CW ID:1 Velocity: 150_middle velocity 300_max
delay(2000);
myservo.rotate(servoNum, -150); // CW ID:1 Velocity: -150_middle velocity -300_max
delay(2000);
myservo.rotate(servoNum, 0); //Stop
myservo.Reset(servoNum); //Only Dynamixel AX need this instruction while changing working mode
//CDS55xx don't need this, it can switch freely between its working mode
break;
case 'r':
myservo.Reset(servoNum);//Restore ID2 servo to factory Settings ( ID:1 Baud rate:1000000)
break;
// case 'i':
// myservo.SetID(2,1);//ID:1 newID:2
// break;
case 'd': //Reset servo to ID>>servoNum. If you don't know your Servo ID, please send "d".
Serial.print("Please wait..");
for (int buf = 0; buf < 255; buf++) {
myservo.SetID(buf, servoNum);
if (buf % 50 == 0) Serial.print(".");
delay(2000);
Serial.println(""); Serial.println("Please close the monitor and re-open it to play your servo! ");
break;
default:
Serial.println("Please give me an available instruction:");
Serial.println(" Servo mode: p_Set position; v_Set velocity.");
Serial.println(" Motor mode: m_Rotate; v_Set velocity.");
Serial.println(" Others: r_Reset servo to factory settings; i_Change servo ID."); Serial.println("");
Leff 2016-01-15 19:09:20 Is anyone else getting their smart servo shield to work, with a Dynamixel AX12 series servo ?!?!
msteven7
msteven7
