sim908 gps google map
arnaud.primoguet 2016-01-24 06:46:01 3132 Views3 Replies I have a arduino mega2560 and a shield sim908
Im searching a programme to get the longitude and the latitude and to send to a http page to view with google map the exact position.
I don' want to send an sms i only want to see in the website my location in real time. I see the website cooking hack but i don't know how to modify the code i need your help
1)Get the location
2)View in a website with Google map
Thank you
1)Get the location
Thank you
2016-01-25 09:46:59 I don' t want to send a message please delete all sms details Thank you very much
int8_t answer;
int onModulePin= 2;
char aux_string[30];
int flag = 0;
char number [20];
char realnumber[9];
char mynumber[9];
int a=0;
int b=0;
int c=0;
//Your phone number
char phone_number[]="012345678";
char data[100];
int data_size;
char aux_str[30];
char aux;
int x = 0;
char N_S,W_E;
char url[] = "pruebas.libelium.com";
char frame[200];
char latitude[15];
char longitude[15];
char altitude[6];
char date[16];
char time[7];
char satellites[3];
char speedOTG[10];
char course[10];
void setup(){
mynumber[0]='0';
mynumber[1]='1';
mynumber[2]='2';
mynumber[3]='3';
mynumber[4]='4';
mynumber[5]='5';
mynumber[6]='6';
mynumber[7]='7';
mynumber[8]='8';
pinMode(onModulePin, OUTPUT);
Serial.begin(115200);
power_on();
power_onGPS();
power_onSMS();
delay(5000);
sendATcommand("AT+CPIN=****", "OK", 2000);
delay(3000);
while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 1000) || sendATcommand("AT+CREG?", "+CREG: 0,5", 1000)) == 0 );
sendATcommand("AT+CLIP=1", "OK", 1000);
while ( start_GPS() == 0);
while (sendATcommand("AT+CREG?", "+CREG: 0,1", 2000) == 0);
// sets APN , user name and password
sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"APN\",\"*******\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"USER\",\"*******\"", "OK", 2000);
sendATcommand("AT+SAPBR=3,1,\"PWD\",\"*******\"", "OK", 2000);
// gets the GPRS bearer
while (sendATcommand("AT+SAPBR=1,1", "OK", 20000) == 0)
delay(5000);
delay(1000);
while(Serial.available() != 0)
Serial.read();
void loop(){
answer = sendATcommand("", "+CLIP", 1000);
//Detect incomming call
if (answer == 1)
Serial.println("Incoming call");
if ( flag == 0){
for (int i=0; i<19; i++){
// read the incoming byte:
while (Serial.available() == 0)
delay (50);
//Stores phone number
number[i] = Serial.read();
Serial.flush();
flag = 1;
//Stores phone calling number
for (int i=0; i<=14; i++){
if(number[i]== '"'){
i++;
realnumber[0]=number[i];
i++;
realnumber[1]=number[i];
i++;
realnumber[2]=number[i];
i++;
realnumber[3]=number[i];
i++;
realnumber[4]=number[i];
i++;
realnumber[5]=number[i];
i++;
realnumber[6]=number[i];
i++;
realnumber[7]=number[i];
i++;
realnumber[8]=number[i];
break;
//Check phone number
for (int i=0;i<9;i++){
if (realnumber[i] == mynumber[i]){
a++;
if( a==9){
Serial.println("Correct number");
sendATcommand("ATH", "OK", 1000);
if(b==1){
b=0;
}else{
b=1;
c=1;
break;
}else{
Serial.println("Wrong number");
break;
a=0;
answer=0;
flag = 0;
//Send SMS once and position to HTTP
if (b==1){
get_GPS();
send_HTTP();
delay(500);
if (c==1){
sendSMS();
delay(100);
c=0;
void power_on(){
uint8_t answer=0;
digitalWrite(onModulePin,HIGH);
delay(3000);
digitalWrite(onModulePin,LOW);
while(answer == 0){ // Send AT every two seconds and wait for the answer
answer = sendATcommand("AT", "OK", 2000);
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
uint8_t x=0, answer=0;
char response[100];
unsigned long previous;
memset(response, '\0', 100); // Initialice the string
delay(100);
while( Serial.available() > 0) Serial.read(); // Clean the input buffer
if (ATcommand[0] != '\0')
Serial.println(ATcommand); // Send the AT command
x = 0;
previous = millis();
// this loop waits for the answer
do{
if(Serial.available() != 0){ // if there are data in the UART input buffer, reads it and checks for the asnwer
response[x] = Serial.read();
//Serial.print(response[x]);
x++;
if (strstr(response, expected_answer) != NULL) // check if the desired answer (OK) is in the response of the module
answer = 1;
}while((answer == 0) && ((millis() - previous) < timeout)); // Waits for the asnwer with time out
return answer;
void power_onGPS(){
uint8_t answer=0;
// checks if the module is started
if (answer == 0)
// power on pulse
delay(3000);
// waits for an answer from the module
while(answer == 0){
int8_t start_GPS(){
// starts the GPS
sendATcommand("AT+CGPSPWR=1", "OK", 2000);
sendATcommand("AT+CGPSRST=0", "OK", 2000);
// waits for fix GPS
while(( (sendATcommand("AT+CGPSSTATUS?", "2D Fix", 5000) ||
sendATcommand("AT+CGPSSTATUS?", "3D Fix", 5000)) == 0 ) &&
((millis() - previous) < 90000));
if ((millis() - previous) < 90000)
return 1;
else
return 0;
int8_t get_GPS(){
int8_t counter, answer;
long previous;
// First get the NMEA string
// request Basic string
sendATcommand("AT+CGPSINF=0", "AT+CGPSINF=0\r\n\r\n", 2000);
counter = 0;
answer = 0;
memset(frame, '\0', 100); // Initialize the string
// this loop waits for the NMEA string
do{
frame[counter] = Serial.read();
counter++;
// check if the desired answer is in the response of the module
if (strstr(frame, "OK") != NULL)
answer = 1;
while((answer == 0) && ((millis() - previous) < 2000));
frame[counter-3] = '\0';
// Parses the string
strtok(frame, ",");
strcpy(longitude,strtok(NULL, ",")); // Gets longitude
strcpy(latitude,strtok(NULL, ",")); // Gets latitude
strcpy(altitude,strtok(NULL, ".")); // Gets altitude
strtok(NULL, ",");
strcpy(date,strtok(NULL, ".")); // Gets date
strtok(NULL, ",");
strtok(NULL, ",");
strcpy(satellites,strtok(NULL, ",")); // Gets satellites
strcpy(speedOTG,strtok(NULL, ",")); // Gets speed over ground. Unit is knots.
strcpy(course,strtok(NULL, "\r")); // Gets course
convert2Degrees(latitude);
convert2Degrees(longitude);
return answer;
/* convert2Degrees ( input ) - performs the conversion from input
* parameters in DD°MM.mmm’ notation to DD.dddddd° notation.
* Sign '+' is set for positive latitudes/longitudes (North, East)
* Sign '-' is set for negative latitudes/longitudes (South, West)
int8_t convert2Degrees(char* input){
float deg;
float minutes;
boolean neg = false;
//auxiliar variable
char aux[10];
if (input[0] == '-')
neg = true;
strcpy(aux, strtok(input+1, "."));
else
strcpy(aux, strtok(input, "."));
// convert string to integer and add it to final float variable
deg = atof(aux);
strcpy(aux, strtok(NULL, '\0'));
minutes=atof(aux);
minutes/=1000000;
if (deg < 100)
minutes += deg;
deg = 0;
else
minutes += int(deg) % 100;
deg = int(deg) / 100;
// add minutes to degrees
deg=deg+minutes/60;
if (neg == true)
deg*=-1.0;
neg = false;
if( deg < 0 ){
neg = true;
deg*=-1;
float numberFloat=deg;
int intPart[10];
int digit;
long newNumber=(long)numberFloat;
int size=0;
while(1){
size=size+1;
digit=newNumber%10;
newNumber=newNumber/10;
intPart[size-1]=digit;
if (newNumber==0){
break;
int index=0;
if( neg ){
index++;
input[0]='-';
for (int i=size-1; i >= 0; i--)
input[index]=intPart[i]+'0';
index++;
input[index]='.';
index++;
numberFloat=(numberFloat-(int)numberFloat);
for (int i=1; i<=6 ; i++)
numberFloat=numberFloat*10;
digit= (long)numberFloat;
numberFloat=numberFloat-digit;
input[index]=char(digit)+48;
index++;
input[index]='\0';
void send_HTTP(){
uint8_t answer=0;
// Initializes HTTP service
answer = sendATcommand("AT+HTTPINIT", "OK", 10000);
if (answer == 1)
// Sets CID parameter
answer = sendATcommand("AT+HTTPPARA=\"CID\",1", "OK", 5000);
if (answer == 1)
// Sets url
sprintf(aux_str, "AT+HTTPPARA=\"URL\",\"http://%s/demo_sim908.php?", url);
Serial.print(aux_str);
sprintf(frame, "visor=false&latitude=%s&longitude=%s&altitude=%s&time=%s&satellites=%s&speedOTG=%s&course=%s",
latitude, longitude, altitude, date, satellites, speedOTG, course);
Serial.print(frame);
answer = sendATcommand("\"", "OK", 5000);
if (answer == 1)
// Starts GET action
answer = sendATcommand("AT+HTTPACTION=0", "+HTTPACTION:0,200", 30000);
if (answer == 1)
Serial.println(F("Done!"));
else
Serial.println(F("Error getting url"));
else
Serial.println(F("Error setting the url"));
else
Serial.println(F("Error setting the CID"));
else
Serial.println(F("Error initializating"));
sendATcommand("AT+HTTPTERM", "OK", 5000);
void power_onSMS(){
uint8_t answer=0;
if (answer == 0)
// power on pulse
delay(3000);
void sendSMS(){
delay(3000);
Serial.println("Connecting to the network...");
while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
Serial.print("Setting SMS mode...");
sendATcommand("AT+CMGF=1", "OK", 1000); // sets the SMS mode to text
Serial.println("Sending SMS");
sprintf(aux_string,"AT+CMGS=\"%s\"", phone_number);
answer = sendATcommand(aux_string, ">", 2000); // send the SMS number
if (answer == 1)
Serial.print("Help me! I've been stolen. Find me in:");
Serial.print("Latitude: ");
int i = 0;
while(latitude[i]!=0){
Serial.print(latitude[i]);
i++;
Serial.print(" / Longitude: ");
i = 0;
while(longitude[i]!=0){
Serial.print(longitude[i]);
i++;
Serial.write(0x1A);
answer = sendATcommand("", "OK", 20000);
if (answer == 1)
Serial.print("Sent ");
else
Serial.print("error ");
else
Serial.println(answer, DEC);
arnaud.primoguet
int8_t answer;
int onModulePin= 2;
int flag = 0;
char number [20];
char realnumber[9];
char mynumber[9];
int a=0;
int b=0;
int c=0;
//Your phone number
char data[100];
int data_size;
char aux_str[30];
char aux;
int x = 0;
char N_S,W_E;
char frame[200];
char latitude[15];
char longitude[15];
char altitude[6];
char date[16];
char time[7];
char satellites[3];
char speedOTG[10];
char course[10];
void setup(){
mynumber[0]='0';
mynumber[1]='1';
mynumber[2]='2';
mynumber[3]='3';
mynumber[4]='4';
mynumber[5]='5';
mynumber[6]='6';
mynumber[7]='7';
mynumber[8]='8';
power_on();
power_onGPS();
power_onSMS();
delay(5000);
delay(3000);
delay(5000);
delay(1000);
Serial.read();
void loop(){
if (answer == 1)
if ( flag == 0){
delay (50);
Serial.flush();
flag = 1;
i++;
i++;
i++;
i++;
i++;
i++;
i++;
i++;
i++;
break;
a++;
if( a==9){
if(b==1){
b=0;
}else{
b=1;
c=1;
break;
}else{
break;
a=0;
answer=0;
flag = 0;
if (b==1){
get_GPS();
send_HTTP();
delay(500);
if (c==1){
sendSMS();
delay(100);
c=0;
void power_on(){
uint8_t answer=0;
delay(3000);
char response[100];
delay(100);
x = 0;
do{
x++;
answer = 1;
return answer;
void power_onGPS(){
uint8_t answer=0;
if (answer == 0)
// power on pulse
delay(3000);
while(answer == 0){
int8_t start_GPS(){
// starts the GPS
return 1;
else
return 0;
int8_t get_GPS(){
long previous;
counter = 0;
answer = 0;
do{
counter++;
answer = 1;
strtok(frame, ",");
strtok(NULL, ",");
strtok(NULL, ",");
strtok(NULL, ",");
return answer;
float deg;
float minutes;
//auxiliar variable
char aux[10];
neg = true;
else
deg = atof(aux);
minutes=atof(aux);
minutes/=1000000;
if (deg < 100)
minutes += deg;
deg = 0;
else
deg=deg+minutes/60;
if (neg == true)
deg*=-1.0;
neg = false;
if( deg < 0 ){
neg = true;
deg*=-1;
int intPart[10];
int digit;
int size=0;
while(1){
size=size+1;
digit=newNumber%10;
if (newNumber==0){
break;
int index=0;
if( neg ){
index++;
input[0]='-';
index++;
input[index]='.';
index++;
index++;
input[index]='\0';
void send_HTTP(){
uint8_t answer=0;
if (answer == 1)
if (answer == 1)
// Sets url
if (answer == 1)
if (answer == 1)
else
else
else
else
void power_onSMS(){
uint8_t answer=0;
if (answer == 0)
// power on pulse
delay(3000);
void sendSMS(){
delay(3000);
if (answer == 1)
int i = 0;
i++;
i = 0;
i++;
Serial.write(0x1A);
if (answer == 1)
else
else
arnaud.primoguet
