Matrix RGB Led 8x8 project (marker)
Account cancelled 2016-02-03 02:02:31 3314 Views0 Replies Hi, I am make a project at school for my degrees ( i am french so my english isn't perfect) so I want to use this matrix RGB led 8x8 with my arduino card (I want to use MBED after):
https://www.dfrobot.com/index.php?route= ... uct_id=780
But I need 16x16 led so I combined 4 matrix but i can't make the program:
I can control only one matrix with this program:
Code: Select all#include <SPI.h>
#define DATA_PIN 11
#define CLK_PIN 13
#define LATCH_PIN 8
// set the LATCH_PIN as an output:
pinMode (LATCH_PIN, OUTPUT);
// initialize SPI:
SPI.begin();
// Autre init SPI à prevoir ?
byte rouge[16] ={B11111111, B00000000, B00000000, B11111111, B11111111, B00000000, B11111111, B00000000, B11111111, B00000000, B00000000, B11111111, B11111111, B00000000, B11111111, B00000000};
byte vert[16] ={B00000000, B11111111, B00000000, B11111111, B00000000, B11111111, B11111111, B00000000, B00000000, B11111111, B00000000, B11111111, B00000000, B11111111, B11111111, B00000000};
byte bleu[16] ={B00000000, B00000000, B11111111, B00000000, B11111111, B11111111, B11111111, B00000000, B00000000, B00000000, B11111111, B00000000, B11111111, B11111111, B11111111, B00000000};
byte anode = {B00000000};
for (int i = 0; i <8 ; i++)
digitalWrite(LATCH_PIN, LOW);
// send in the address and value via SPI:
// Colonne 1,2,3 en bleu
SPI.transfer(bleu[i]);//B
SPI.transfer(vert[i]);//G
SPI.transfer(rouge[i]);//R
switch (i)
case (0):
anode = B00000001 ;
break;
case (1):
anode = B00000010 ;
break;
case (2):
anode = B00000100 ;
break;
case (3):
anode = B00001000 ;
break;
case (4):
anode = B00010000 ;
break;
case (5):
anode = B00100000 ;
break;
case (6):
anode = B01000000 ;
break;
case (7):
anode = B10000000 ;
case (8):
anode = B00000001;
break;
case (9):
anode = B00000010 ;
break;
case (10):
anode = B00000100 ;
break;
case (11):
anode = B00001000 ;
break;
case (12):
anode = B00010000 ;
break;
case (13):
anode = B00100000 ;
break;
case (14):
anode = B01000000 ;
break;
case (15):
anode = B10000000 ;
break;
SPI.transfer(anode);//Anode
// take the SS pin high to de-select the chip:
digitalWrite(LATCH_PIN,HIGH);
SPI.transfer(bleu[i+8]);//B
SPI.transfer(vert[i+8]);//G
SPI.transfer(rouge[i+8]);//R
switch (i)
case (0):
anode = B00000001 ;
break;
case (1):
anode = B00000010 ;
break;
case (2):
anode = B00000100 ;
break;
case (3):
anode = B00001000 ;
break;
case (4):
anode = B00010000 ;
break;
case (5):
anode = B00100000 ;
break;
case (6):
anode = B01000000 ;
break;
case (7):
anode = B10000000 ;
digitalWrite(LATCH_PIN,HIGH); }
delay(1); // 1ms de pause avant envoy d'un autre message
And I don't understand how it's work with 4 matrix connected ( to make a square of 2 on 2).
Thank you to help me ![]()
