I2C LCD Display
userHead Account cancelled 2016-02-03 14:22:11 2312 Views1 Replies
I'm using DFR0154 LCD display and it works great! However, I need a display that can be used both in direct sunlight and in the dark at night. Therefore I need programmable light intensity for both the backlight and the text field. I also need 40 characters (minimum) by 4 rows,
Question: does DFROBOT make any such LCD display? Any suggestions?
Thank you,
John
2016-02-03 23:01:31 I've used this shield in some projects. It fits neatly on top an Arduino UNO or similar type board.
https://www.dfrobot.com/index.php?route= ... rGlIVJHYa0
Contrast settings are managed in software and it also supports different fonts. Will this do?
userHeadPic Maht
