PM2.5 Sensor Module (SEN0177) sleep mode
userHead wojtemac 2016-03-04 06:07:14 3066 Views3 Replies
Hi .
I have PM Laser sensor (SEN0177).
Now it's working in continuous mode, but I will to set it to sleep mode every hour.
How can I do it from program?
thanks .
Wojtek
2016-03-07 22:43:05 Hi Wojtek,
Thanks for your sharing!
To power it through digital pins is not a good idea, cause the I/O pins could only output 50mA current, but I checked the PM module specifiction, its Maximum electric current: 120mA... So...you know..you got to have a relay module, it's not expensive.
Btw, just for chat, which city you are in, also have problem of air polution? Just wonder about that cause I am an environmentalist, I am in Shanghai, air is bad most of the time.... :|
userHeadPic Leff
2016-03-04 23:14:50 Hi.
Thanks, I though so :(
Unfortunately I don't have a relay module and probably won't get one, but I think I can connect VCC to other pin (through an capacitor) and switch it HIGH or LOW.
Maybe it could work.
Actually I have 3 of them, and we will measure air pollution in 3 different points of our city. Just to get SOMG info.
BR
Wojtek
userHeadPic wojtemac
2016-03-04 18:14:39 Hi,
I checked with the module-PM2.5 sensor, it will output data automatically once get powered. So there might be only one way to make your idea possible that is to use a Relay module, power on/off every hour.
May I know what purpose do you use PM2.5 for? Just very curious to know, :D
userHeadPic Leff
