[problem solved]GPS/GPRS/GSM Module V3.0 USB connexion using
userHead baiteche_kamel 2016-03-16 10:34:52 4841 Views12 Replies
Good evening,
I just bought the GPS/GPRS/GSM Module V3.0.
the problem is that I was unable to make it work. I use a USB-UART Adapter and CoolTermWin program to send AT command.
no result.
has the following configuration:
S1: Comm Mode
S2: USB mode
S3: UART Select
J10, J11 and J12 with jumpers.
LED indicator:
PWR: red
STAT: off
NET: off
Code: Select allUSB <=============> GPS / GPRS / GSM Module V3.0.
TX---------------------------- > RX
RX---------------------------- > TX
5v ----------------------------> 5v
GND -------------------------> GND
Thank you in advance for your help.
sorry for my English :oops:
2016-03-19 02:00:29
Leff wrote:I think I must be out of mind when I was answering your question...anyway, you could use that USB&External power source at the same time.
Good day!
Leff, a big thank you for all the help you gave me.
have a good day ;):)
userHeadPic baiteche_kamel
2016-03-19 02:00:29
Good day!
2016-03-19 01:50:44 I think I must be out of mind when I was answering your question...anyway, you could use that USB&External power source at the same time.
Good day!
userHeadPic Leff
2016-03-18 07:53:13 Hello again,
this has not agreed on the issue,
I explain:
Arduino and Shields are connected and powering by batterie.OK
and besides that I want to send AT command, so I have to plug in
USB cable.
Or I have to disconnect the battery and connect the USB?
thank you.
2016-03-18 02:34:19 Hi baiteche_kamel,
This is what I used before, https://www.dfrobot.com/index.php?route= ... uct_id=489, be noted that Voltage and current output should both be considered. ;)
userHeadPic Leff
userHeadPic Leff
2016-03-18 01:22:46 Leff thank you,
does not work I think this is due to lack of electrical power.
but works with external power supply Could I Showed you. I send an SMS.
So the module works very well.
my question:
May I use the external power supply to supply the module and use USB cable to communicte with the module (same time).
2016-03-17 19:14:24 Hi,
1) I am not sure if the power 300mA is enough? Better with a larger one.
2) I suggest you could start with GPS, it only needs USB cable for power supply on your Uno, don't have to consider the external power supply.
userHeadPic Leff
2016-03-17 12:00:09 Hello again,
I lent an Arduino UNO, I want to know if I can use the USB cable and an external power supply at the same time.
and if not how to feed (Arduino UNO and GSM / GPS Shields V3) and communicates using a terminal
thank you
2016-03-17 02:42:33 Hello,
thank you for helping me Leff, look image 1: I receive corrupted data.
may be because of dfrobot that I use looks at the image 2.
I measure the voltage with a multimeter indicates 12.24V and current indicates 12.6 mA.
2016-03-16 19:01:42 Your English is good, and you have described your wiring very clearly! Very impressive!
But the power connection is not correct, please use an external power supply([email protected] is suggested), and through Vin instead of 5V.
I also draw something like you do :D
userHeadPic Leff
2016-03-16 10:34:52 Good evening,
no result.
S1: Comm Mode
S2: USB mode
S3: UART Select
LED indicator:
PWR: red
STAT: off
NET: off
Code: Select all
