GPS/GPRS/GSM Module V3.0 suport FTP and 3G or 4G??
Augusto de Andrade Gomes Arthur 2016-03-23 04:37:54 3685 Views5 Replies Hello, I wonder if the GPS module / GPRS / GSM Module V3.0 supports 3G (WCDMA), and is FTP connection, with or without 3G.
For I am doing my college course conclusion work and bought this module, since I am one month working on it and yet could not send this data via FTP only by SMS.
PLEASE HELP ME
PLEASE HELP ME
2016-03-25 19:01:48 I've seen this topic but it is another model SIM908, was not developed by DFROBOT, the commands are already the I'm using but still does not work. I do not know what to do, I'm thinking of buying a separate 3G module for testing.
Augusto de Andrade Gomes Arthur 2016-03-24 23:45:32 Hey, guess what, I found this tutorial using the same chip, there you could find some code for arduino...
maybe you could have a try
https://www.cooking-hacks.com/documenta ... rry-pi#ftp
Leff
Leff 2016-03-24 05:59:03 It is to send only .txt files with the coordinates lat and long. but not send the connection failure, I have tried everything, only 2G support is very bad. you can not send a single file in .txt
Augusto de Andrade Gomes Arthur 2016-03-24 02:25:46 Only support 2G, while FTP is supported, cause I found many relavent AT commands in its AT command lsit, but I am not familiar with FTP/ http... web things
Will you use it to send large amount data to "FTP" server(not sure if my question is stupid~)?
Leff
Leff
