Hitec 805BB+ Mega 1/4 Scale Servo (24.7kg)
Account cancelled 2016-03-24 06:40:28 2149 Views1 Replies Hi,
I need to find a servo motor that can rotate a 144 mm, 16 mm diameter pH probe lengthwise from its center when attached through a connector piece to the servo. The probe is roughly .09 kg.
Would the one I mentioned above be a good choice?
Thanks.
Thanks.
2016-03-24 23:52:03 Sure I think it can, if you didn't make any typo mistake, the servo even at 4.8V could rotate something at 20Kg/cm, so the .09Kg should be VERY generously given. If I were you, tyo life something like 0.09kg, I would use a much smaller one like 9g micro servo (1.6kg)
Torque @ 4.8V: 274.96 oz-in (19.8kg/cm)
Leff
Leff
