GETTING DISPLACEMENT FROM MPU6050
userHead ben amara ramzi 2016-03-26 09:44:27 4187 Views1 Replies
HI,
I need to know if there is a solution to get displcaement in mm from mpu6050.
I know that using kalman filter we can have accurate angular position; but I need to have displcament or position of my object not the orientation .
Thank you for your help!
2016-03-29 02:48:35 Hi Ben,
Sorry for the belated reply!
But I didn't get you for "get displcaement in mm from mpu6050. "?
And as to "need to have displcament or position of my object not the orientation . ", do you want to know where is it in some designed area or its globel longitude and latitude?
userHeadPic Leff
