Mega Sensor Shield (DFR0165) v2.4 SVG schematics
userHead StephenParry 2016-04-27 14:12:30 10208 Views19 Replies
Please can you supply updated versions of the Mega Sensor Shield schematics in SVG? I want to create a Fritzing part for the board, but the SVGs currently available through github etc. are for the earlier boards. Some are mislabelled. The 2.4 layout is subtly different, e.g.. the board is wider, the connector-to-connector spacings have changed and the connector counts now support the Arduino R3 specs.
2016-11-23 18:31:22 OK, thank you so much for your support! :):) userHeadPic Wendy.Hu
2016-11-22 19:23:58 It took 2 and a half days, but I did it myself, using the current SVG and correcting it using the standard Arduino and XBee schematics and digital vernier caliper readings - not perfect but a lot better than the current SVG. The current SVG is obviously hacked together. None of its dimensions are accurate, even between pins. For use in Fritzing, it is essential that the dimensions (especially pin spacings) are correct, otherwise the SVG is useless.
Please check this new version and put in your repo until proper version available.
userHeadPic StephenParry
2016-11-16 20:02:30 Hi Stephen,
I will give a feedback to our team, hope there will be an update. :)
2016-11-16 15:18:52 I appreciate that there could be copyright and compatibility problems. However, there have been layout / pinouts issued in both SVG and PDF formats previously. Updated versions of these would be sufficient - just something that allows me to move the pins on the SVG to the correct positions. The SVG posted here and in GIT is very inaccurate - most of the pin positions and the holes do not line up with their mates on the Arduino Mega board. userHeadPic StephenParry
2016-11-15 22:08:39 Hi Stephen,
Our PCB file is designed in the other paid software, not eagle. So that will be a copyright and compatibility problem.
userHeadPic Grey.CC
userHeadPic Grey.CC
2016-11-15 14:52:26 Hi again, I finally got around to making the Fritzing part (I had other issues!) but some of the pin positions are not accurate - Any chance I could get a copy of just the drilling and holes layer from Eagle please, or an export in DXF format? I could use those to correct the positions of the pins. Thanks. userHeadPic StephenParry
2016-04-30 22:08:20
StephenParry wrote:Fantastic, Thank you! :D:D:D
Glad to help.
userHeadPic Leff
2016-04-30 22:08:20
Glad to help.
userHeadPic Leff
2016-04-30 11:53:08 Fantastic, Thank you! :D:D:D userHeadPic StephenParry
2016-04-29 01:56:18 Hi,
The DF-Jane/DFRobot-SVGs is out of date. Please find the attachment, hope it helps.
userHeadPic Leff
userHeadPic Leff
2016-04-27 14:12:30 Please can you supply updated versions of the Mega Sensor Shield schematics in SVG? I want to create a Fritzing part for the board, but the SVGs currently available through github etc. are for the earlier boards. Some are mislabelled. The 2.4 layout is subtly different, e.g.. the board is wider, the connector-to-connector spacings have changed and the connector counts now support the Arduino R3 specs.
