Material of construction for turbidity Sensor SEN0189
userHead Account cancelled 2016-05-03 05:44:40 2051 Views1 Replies
I am planning to purchase the turbidity sensor (SEN0189) for a salt solution application. Can you tell me the material used in probe construction (the part in contact with the fluid)? I could not find this on the product wiki and need to cross-check its compatibility with our solution before purchasing.
Thanks!
2016-05-04 03:00:55 Hi
The material used in probe construction(the part in contact with the fluid) is PP.
userHeadPic Wendy
