GPS-GPRS-GSM-Shield-V3.0 auto shut off w/ serial connection
yuesu87 2016-05-07 20:07:52 11005 Views1 Replies Hi,
I had been trying to get a GPS-GPRS-GSM-Shield-V3.0 to send GPS data over either HTTP or FTP via AT command.
While trying to setup the GPRS network, a bug occurred midway (it started transmitting random char.) and right after, I can't get the shield to receive AT commands.
I have tried restarting the shield multiple times, each time the shield initiate normally with Stat and Net LED turned on. The moment I connect to the shield via serial, both green light would turn off. I had tried diagnosing the problem with Module Tester. On the rare occasion a connection was establish, it would display a response like "normal power off".
The arduino has been setup with the 1.5 sec gsm timing and digital high on pin 3&4. I have a fully charged 7.4V 1c lipo connected to the arduino power socket. S1 pin is set on Comm, S2, on USB, and UART pin on GSM.
Can someone help me solve with this issue?
Thank you!
Thank you!
2016-05-07 21:38:15 Hi Leff,
Thank you for your swift response.
I have followed your instructions, by pressing on the Reset button, the Sat LED is on and Net LED is blinking.
On all the coolterm, a '.' was sent from shield. However, it doesn't respond to any serial command.
The shield is placed right next to window and I have waited a little while. Nothing changed.
Can you clarify the reason for which the shield need to be placed outside when I am only using GPRS?
Is initiating GPS part of the startup procedure of the shield?
yuesu87
yuesu87
