DRI0023
userHead zaltys 2016-05-19 10:58:33 3490 Views13 Replies
On my motor shield DRI0023, there are 9 pins in the right row and 8 in the left one.
Neither in the DFR Wiki, nor in the A4988 datasheet this ninth pin appears.
Any help, please ?
Thanx a lot.
2017-02-15 21:54:41 Hi Mathieu,
Sorry for the late reply.
Since we need to connect two motors to the board, there are two driver chips and two VMM pins, which is connected to same points.
userHeadPic Wendy.Hu
2017-02-12 17:37:46 Hi zaltys,
Have you tried to replace with a stock 8pins chip at the end ? how did it worked ?
Did you identified which pin was the 9th ? is it the ENABLE pin ?
Mathieu
userHeadPic clertem
Mathieu
userHeadPic clertem
2016-05-25 02:26:46 Thanx for your kindness. ;) userHeadPic zaltys
2016-05-23 20:33:29 Hi
You can have a try to find a new brand with 17 pins . And because our sample code donnot need a libraray, theoretically you can put a 16 pins instead of original driver.
2016-05-21 06:53:42 Hi,
Thank you for these informations.
Another question please. If I "toast" a driver on this motor shield, is it possible to find a brand new 17 pins or can I put a 16 pins one instead of the original driver ?
Have a nice day.
userHeadPic zaltys
Have a nice day.
userHeadPic zaltys
2016-05-19 18:57:44 Hi
Its strange. Do you have a picture?
2016-05-19 10:58:33 Hi,
Any help, please ?
Thanx a lot.
userHeadPic zaltys
