Wifi Bee ESP V1.0 on Mega Sensor Shield
userHead Account cancelled 2016-06-03 10:57:08 1979 Views1 Replies
Can't seem to get the Wifi Bee to wake up on the Mega Sensor Shield. Some chatter about this bee module needing 3.3v exactly. Anyone seen any issues with this? I'm measuring 3.28 at the Xbee2 socket.
Dave
2016-06-04 01:51:58 is it this one what you use? https://www.dfrobot.com/index.php?route= ... ption=true
If so, I played it before using 5V, it could be used. Can I have a look at your code that what to make sure:
  1. have you use the Serial2.xxx() in your code?
  2. The baud rate (if it is the same as the module setting?)
userHeadPic Leff
