RF Shield help
userHead Account cancelled 2016-06-11 07:09:10 1742 Views1 Replies
Hi All,
I bought a tel0075 and three (3) FIT0355 remotes and they work perfectly...in fact...too good.
How can I limit which remotes trigger the shield? What if someone has the a FIT0355 remote in their pocket for an other project and my shield picks it up?
The instructions for this shield are very very slim.
Can any one help me?
Thank you,
Ozzie
2016-06-12 22:42:58 Hi
I am sorry that the wiki is not very clear, but you can limit the remote. Here you can disassemble the remote control to revise the address code. When disassembled, you will see the situation as shown in the following picture.
Then you will see three rows of metal welding points, the first row is grounding terminal, the second row is address pins, and the third row is high level terminal. Now as the picture shown, the adress is Floating; if you use the soldering iron to connect the first two rows, the adress will changed to Low; if you connect the second and third rows, the adress will changed to High.
Now only if the adress codes are same betweeen the controller and the shield, you can limit the remote. userHeadPic Wendy.Hu
