How do I put into a buffer, a part of Serial response (UART)
pierrot10 2014-09-11 10:49:43 2615 Views1 Replies May be let show it simplier.
Here is my new code.
It should
1. start the module, read the response of AT
2. Go to GSM mode
3. Power and rest GPS, read the response of AT+GPSPWR....
[quote]****************************
STARTING SYSTEM Read AT stream
AT
> Module is started UP
------- Show buffer------
ÿÿÿþÿÿÿ
RDY
+CFUN: 1
+CPIN: READY
AT
OK
Call Ready
GPS Ready
> Enabling GSM
> Powering GPS
AT+CGPSPWR=1
ÿÿÿþÿÿÿ
RD
> Powering GPS
AT+CGPSPWR=1
OK
> reset GPS in autonomy mode
AT+CGPSRST=1
ÿÿÿþÿÿÿ
RD
> Powering GPS
AT+CGPSPWR=1
OK
------- Sho
[/quote]
And this is my problem.
the read_AT_string is supposed to send the AT command and store in a buffer, the response ONLY of the sent AT command.
Apparently, it store anything and keep all Serial communication even if I clean the buffer
[quote]
The "AT" or "at" prefix must be set at the beginning of each Command line. To terminate a
Command line enter <CR>.
Commands are usually followed by a response
that includes. "<CR><LF><response><CR><LF>"
Throughout this document, only the responses are presented, <CR><LF> are omitted
intentionally.
[/quote]
How can I adapt my read_AT_string function to make sure, it will store, into the buffer, ONLY the response, wich are between < CR>< LF>?????????
THIS IS MY BIG problem, I want to buffer the response. Pls help, me I spent all day on it
I think the Serial should be cleaned before sending a new AT command, or to filder content between <CR><LF> and I am not able to do that.
Otherwise, does my simpe code sound good?
Many thnyk!!!
It should
2. Go to GSM mode
The module is UP but the display is a mess:#include <SoftwareSerial.h>
int baud_rate = 9600;
int pin_gsm = 3;
int pin_gps = 4;
int pin_power = 5;
//int pin_dtr = 6;
boolean debug = true;
boolean raedy_to_go = false;
// Reading String
#define BUFFERSIZE 200
char buffer[BUFFERSIZE];
char inChar;
int index;
Serial.begin(baud_rate);
delay(5000); // Wait for 5sec after begin
if(debug)
Serial.println(F("\n****************************"));
Serial.println(F("STARTING SYSTEM Read AT stream"));
Serial.println(F("******************************"));
pinMode(pin_gsm,OUTPUT); // Set the pins
pinMode(pin_gps,OUTPUT);
pinMode(pin_power,OUTPUT);
digitalWrite(pin_power,HIGH);
delay(1500);
digitalWrite(pin_power,LOW);
// The module is started but I want to be sure it has really started
// I send an AT command and I should receive an response RDY
// That function should
// 1. Send the AT commans
// 2. Store the response in a buffer
if(strstr(read_AT_string("AT",5000),"RDY") != NULL)
Serial.println(F("\n> Module is started UP"));
Serial.println(F("------- Show buffer------"));
Serial.println(buffer);
Serial.println(F("-------------------------\n"));
// Enabling GSM
gsm_enable();
Serial.println(F("\n> Powering GPS"));
Serial.println(read_AT_string("AT+CGPSPWR=1",5000));
// AT+CGPSPWR, should it return OK
Serial.println(F("\n> reset GPS in autonomy mode"));
Serial.println(read_AT_string("AT+CGPSRST=1",5000));
// AT+CGPSRST=1, should it return OK
else{
Serial.println(F("> Module is NOT started UP"));
char* read_AT_string(char* command, int timeout)
unsigned long previous;
previous = millis();
index=0;
// Clear the buffer
buffer[0]='\0';
// SEND THE AT COMMAND. I AM ASKING IF I HAVE TO KEEP THE ln
Serial.println(command);
do
if(Serial.available() > 0) // Don't read unless
if(index < BUFFERSIZE-1)
//Serial.println("b");
inChar = Serial.read(); // Read a character
buffer[index] = inChar; // Store it
index++; // Increment where to write next
// BUFFER CONTAINING THE DESIRED RESPONSE
buffer[index] = '\0'; // Null terminate the string
}while(((millis() - previous) < timeout));
return buffer;
void gps_enable(void)
if(debug)
Serial.println(F("\n> Enabling GPS"));
digitalWrite(pin_gps,LOW); //Enable GPS mode
digitalWrite(pin_gsm,HIGH); //Disable GSM mode
delay(2000);
void gsm_enable(void)
if(debug)
Serial.println(F("\n> Enabling GSM"));
digitalWrite(pin_gsm,LOW); //Enable GSM mode
digitalWrite(pin_gps,HIGH); //Disable GPS mode
delay(2000);
AT
ÿÿÿþÿÿÿ
RDY
+CFUN: 1
+CPIN: READY
AT
OK
Call Ready
GPS Ready
> Enabling GSM
> Powering GPS
AT+CGPSPWR=1
ÿÿÿþÿÿÿ
RD
> Powering GPS
AT+CGPSPWR=1
OK
AT+CGPSRST=1
ÿÿÿþÿÿÿ
RD
> Powering GPS
AT+CGPSPWR=1
OK
------- Sho
[/quote]
Now, I red thisbuffer[0]='\0';
[quote]
intentionally.
[/quote]
Many thnyk!!!
2014-09-11 21:31:05 Is that any possible that "response" is the response time? Or you think it is a content?
After Serial port sends the Command, it will clean the buffer every time.
Grey.CC
Grey.CC
