360 Degree Lidar Accuracy
Account cancelled 2016-07-01 09:27:51 2143 Views1 Replies Hello,
My team purchased the A1 version of the 360 degree Lidar Laser Scanner for our project. Our project is very dependent on the accuracy of the sensor. The Lidar is listed as having a less than 0.5 mm error (or < 1% of the distance). After some testing of the sensor against a flat white wall we have found the sensor does not have this level of accuracy.
We tested the Lidar at a distance of 1 and 3.5 meters. The tests had the robot report its minimum value over a range of angles to determine the perpendicular distance to a flat wall. The program output its measurement every 500 ms. We then collected data and graphed it. We found that the lidars reading changed over time and that it was not within the 0.5 mm accuracy. The Test results are shown in the attached excel file with different tabs for different tests. To see the angle correlated to each distance reading allow the filter on the fourth column to display 0's.
As visible in the file for the 1 meter test the data ranged from 1000 to 1017 and for the 3.5 meter test the data ranged from 3353-3488. These range of results for both these tests exceed the listed accuracy of < 1%.
I am hoping to learn if we have a defective product or if this error is common in all the RPLidars.
Thanks for the help.
2016-07-01 23:46:01 Hi im.jdowns,
Sorry, this lidar is our agent product, you can contact our agent directly.
Here is their email Slamtec Support <[email protected]>.
Wendy.Hu
Wendy.Hu
