Mega Sensor Shield V2.4 don't work together with Yun Shield
userHead Tutak Marek 2016-08-09 01:00:44 2539 Views2 Replies
I plan to use Mega Sensor Shield V2.4 in my the production devices. But I have a problem. Mega shield uses pin MISO, MOSI, SCK to communication with SD card. In my project pins TX0/RX0, MISO, MOSI, SCK used by the sield Yun (during programming Arduino). Even if not SD cart in socket. I must unsolder R7 and R9 then programming was going. But when insertet SD card again can't progamming.
I have 2 questions:
1. How many shields minimum I must order that you make the following changes:
a. all signals going to SD cocket (MISO, MOSI, SCK and SS) will be buffered by two SN74LVC2G126? OE signal connected to Arduino PIN PJ6 ( PCINT 15 )?
b. XBee cradles would be allocated in the following manner TX1 / dfrobot (XBee1), TX2 / RX2 (XBee2) and TX3 / RX3 (XBee3)? TX0 /RX0 is using by Yun shield when programming Arduino.
2. How long I must wait for this changes?
Best regards
Marek
2016-09-01 07:06:38 I send you PM. userHeadPic Tutak Marek
2016-08-10 02:09:17 Hi Marek,
Thank you for your interest in our products. Please find the conditions of our customization service below:
- Please make sure that:
- Your order quantity reaches 100-1000 units (depending on the specific items)
- The related items within the customization order are attainable
- We appreciate if you can offer us with a standard Requirement for Proposal telling us about company/ yourself and your project, including following info:
- The field/area you are engaged in
- Your application’s field/ area
- Description of customization with details like features, size, weight, etc.
- If there is a similar product on the market
- Your project’s schedule (if possible) and our expected delivery deadline
- How many units are required and if you will order again in future
- Any request for certification?
- We will advise whether your order is possible within one week. If it is possible, a quotation will also be attached. (Please note that there will be an extra fee for customization services).
userHeadPic Wendy.Hu
