SENS-FS-IR02
Account cancelled 2016-08-26 17:37:32 1574 Views1 Replies Hello. The specification sheet on your website says that the SENS-FS-IR02 requires a supply voltage of 5 Vdc. I need to input to a 3.3 Vdc only input. I tried running this sensor on 3.3 Vdc and it seems to work just fine. Is there any reason that I cannot continue to run the sensor at 3.3 Vdc?
2016-08-27 01:02:51 Hello,
If the sensor works fine on 3.3V, there is no problem. But maybe it will effect the stability of the sensor.
Wendy.Hu
Wendy.Hu
