DFrobot relay shield V2.1 how to program xBee
calvinlove29 2014-12-25 08:23:35 7148 Views9 Replies Hey guys I had recently purchased the dfrobot relay shield v2.1 and also an xBee module. I got everything wired down as shown below:
i cant seem to attach the image so here is a link to download the image.
https://www.dropbox.com/s/tyihxaqsf3wlz ... t.JPG?dl=0
https://www.dropbox.com/s/f5kewwo8nxlhy ... 2.JPG?dl=0
Relays are all working with the sample code and on the analog sides are all to my float sensors so you guys can ignore that.
The associate light seems to be on but when im reading through xctu it doesnt seem to be able to find any modem connected.
The purpose of the project is so that i can connect the arduino to my wireless connection and make it to host a webpage where i can control the relay by accessing the web page.
i know its christmas eve and all but if someone can guide me on what I need to do to be able to read the Xbee or what i need to configure hardware terms to get it going. Thank ahead
2015-01-16 05:47:03 Hello Jay,
Have you finished the wireless communication now? So what you want to do is a wireless speed control?
I guess you have met the problem about the serial recognition, right?
Grey.CC
Grey.CC 2015-01-14 10:26:40 Hello
I have a project to submit and its too late i cant find the right answer anywhere. I want to send pwm signals through my xbee series 2 to another xbee series 2 can you tell me how to i do that and there are 4 motors and they are small. Please help.
KavomatovlKiz
KavomatovlKiz 2015-01-10 06:29:09 Ok if i were to change it to ethernet shield will the conflicting pin affect the ethernet shield? as in pin number 10
calvinlove29
calvinlove29 2014-12-30 22:09:17 Yes it is a wifi Xbee module , so is it possible to host a webserver on arudino through this?
calvinlove29
calvinlove29 2014-12-27 01:43:44 Hello,
It requires a xbee wifi module. I am not sure whether it is. The photo is not very clear.
If this is a wifi xbee, it is better to configure its network parameter first.
Grey.CC
Grey.CC 2014-12-26 06:44:32 https://learn.sparkfun.com/tutorials/in ... -xbee-wifi
this was the actual thread i read before i decided to go with xbee for my project.
calvinlove29
calvinlove29 2014-12-26 06:36:00 thanx grey for the feedback, currently i do not have the USB adaoter for the xbee,
and regarding the Xbee as a zigbee device , I am quite new into all this, so I would appreciate it if you can explain it to me, and is there any way that i can use it with my arduino Uno to host a webpage to control the relay
calvinlove29
calvinlove29 2014-12-26 00:34:08 Hello Calvin,
Do you have an USB xbee adapter?
It is better to use this module to set its configuration.
And I remember xbee is a zigbee device, how do you make a website control?
Grey.CC
Grey.CC
