SIM908 [TEL0051] and Intel Edison
userHead mbardier 2016-10-14 15:53:14 2674 Views2 Replies
I couldn't make SIM908 shield [TEL0051] work on Intel Edison.
When power up, I didn't even light up the PWR light, neither STAT or NET lights...
Any suggestion ?
2016-10-20 15:11:05 I powered the shield with a 12V 2Amp source as I previously been doing with the Edison.
The same shield (SIM908 [TEL0051]) did work on an Arduino Uno and a Robotale Mega 2560 but failed to light up its PWR light when plugged to the Edison...
Does any one know about compatibility issues with the Edison or a workaround to the problem ?
userHeadPic mbardier
2016-10-20 02:22:03 Which intel edison shield did you use? Did you connect an external supply to the shiled? userHeadPic Wendy.Hu
