Is USB to TTL module required for DF Bluetooth V3 Module?
Account cancelled 2016-11-11 07:11:09 2170 Views1 Replies Hello,
I am trying to connect my Romeo V2 all in one controller (SKU:DFR0225) to my computer via bluetooth using the DF Bluetooth V3 (SKU:TEL0026).
In the tutorial instructions on the page for the Bluetooth module above, it mentions using this USB to TTL module to set things up on my computer.
This component did not not come with my robot kit, so I am wondering, do I need this USB to TTL module to get the connection to work, or is there another way of setting it up?
Thanks,
Jack
Thanks,
Jack
2016-11-11 23:23:46 Hi Sir,
May I confirm that you want to establish communication between your computer and the romeo through Bluetooth? If so, maybe you need to connect an adapter to your computer, like: TEL0002-you can search it on our website page. Then if you have a IO shield-DFR0219, no need to use USB to TTL module, you can insert the Bluetooth module to the APC220 interface, then build connection between your computer and the romeo.
Contact us if you have any problem.
Wendy.Hu
Wendy.Hu
