Can I drive a DFR0251 with 3.3 volt on the input side?
userHead Account cancelled 2016-11-26 14:23:54 1683 Views1 Replies
If not, can I safely use a 3.3v to 5v DC-DC stepup breakout board between the 3.3v arduino compatible card and the DFR0251?
2016-11-29 00:19:56 Hi Sir,
I did a test, then the 3.3V still can drive the module. But I guess the 5V should be more stable. You can try again via yourself.
Contact us if you have any problem. :)
userHeadPic Wendy.Hu
