mpr121 using as liquid level sensor
userHead mkhalilsm 2017-01-05 10:20:22 2451 Views1 Replies
I was trying to use the mpr121 as a liquid level sensor. I had a copper tape and soldered wires stick to a plastic bottle at levels. I use the capatouch.touch() method to check if sensor has the water level at the point as i pour water into the container. I did not see any changes.
Do i have to make any changes to the touch() to be able to read changes to capacitance via rising liquid rather than a physical touch to the copper plates.
Thanks.
2017-01-09 22:40:32 Hi Sir,
If you want to measure the liquid level, I would like to suggest you choose these sensors as follows:make_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.dfrobot.com/index.php?route=product/search&search=liquid&description=true', '', ' class="postlink"')
The mpr121 sensors I think cant be used as a liquid level sensor, only a touch module. :)
userHeadPic Wendy.Hu
