Arduino Beginner's Kit - locks up on compile
userHead abx719 2017-01-18 12:24:08 2823 Views6 Replies
The compiler locks up on project two every time - no error message[attachment=0]uno.jpg[/attachment]
icon uno.jpg Download(0)
2017-01-20 22:08:34 Hi Sir,
Its so strange! I have no idea about that. I would like to suggest you can go to download the IDE version of 1.6.8 or to 1.6.12. These several versions are relatively stable.
Hope this will help you.
userHeadPic Wendy.Hu
2017-01-20 07:35:57 Downloaded 1.8.0 but it would not install. userHeadPic abx719
2017-01-19 14:46:24 When I copy the text from the DFRobot PDF guide - and paste into a word processor as unformatted text and then paste it in, it will work as opposed to when I type it myself. Thid has worked twice.
The most likely errors I would have made in typing it in would be missing or wrong punctuation::
which shouldn't lock the compiler?
userHeadPic abx719
2017-01-19 07:05:07 I'm running Windows 7 Home ... (I know, I know) userHeadPic abx719
2017-01-19 06:54:40 Hi - having problems again this morning! It's locked up on project three.
Which other IDE? I downloaded Arduino 1.8.1 for Windows here:
make_clickable_callback(MAGIC_URL_FULL, '
', 'https://www.arduino.cc/en/Main/Software', '', ' class="postlink"')
thank you so much for your help,
Stephen
userHeadPic abx719
2017-01-19 01:59:51 Hi,
Its a little strange. Did you try the other IDE to see what happened? I guess probably its the problem with the IDE.
Let me know if you have any problem.
userHeadPic Grey.CC
