SEN0175 UV Sensor v1.0 - ML8511
userHead yohan5034 2017-02-11 12:17:56 1737 Views2 Replies
Hello, my name is Yohan Alzate and I have a Project with that sensor, the idea is measure the UV intensity from an UV lamp in a flexographic machine with that sensor and i want know what do you think about this? is posible?, at the moment i have 2 sensors of these for to do a test.
Best Regards.
2017-02-21 18:24:16 Hello, Wendy thank you for you answer i will try test it. ;) userHeadPic yohan5034
2017-02-15 19:51:16 Hi
Sorry, I dont know much about the flexographic machine. In theory, it should be no problem, only if put the sensor near to the lamp. You can have a try.
Let me know if you have any problem. :)
userHeadPic Wendy.Hu
