DF Player Folder Playback
userHead nagarajulrpt 2017-02-16 13:16:18 1285 Views1 Replies
i want play all the files in a folder in sequential manner. when i execute serial cmd with "0x0F" it wasn't playing after some 5 to 10 seconds.
can any one help in this?
2017-02-16 22:06:34 Hi
May I confirm does the module work when you used the code in our wiki? Or just dont work when you send the command? If yes, whats the whole command did you send via the serial port? And how did you connect your diagram? TX-TX RX-RX? As I know, if you want to play all the files in a folder, you need to send the following command:
7E FF 06 11 00 00 01 FE E9 EF or 7E 11 00 01 EF
And please make sure your files format is correct, more detailed info please refer to our wiki.
Let me know if you have any other problem. :)
userHeadPic Wendy.Hu
