Dual Bipolar Stepper Motor Shield (DRV8825) Pin Out
userHead Account cancelled 2017-03-24 20:11:52 3503 Views1 Replies
How do you use this board with an Arduino? There is no step or dir pin. The wiring guide on the product page only shows how to connect the motors to the board, but not how to connect the controller. I was hoping to use the stepper motor library that I am already familiar with-AccelStepper. The item is here: https://www.dfrobot.com/product-1060.html
Thanks in advance.
Tyler
2017-03-28 22:07:50 Hi
This board is compatible with Arduino UNO R3, Leonardo, Mega and other controllers, with full port extensions. Just insert this board into your controller, it will be ok. 8.2-45V DC (Just power the stepper motor driver), 1.6A output current per coil
userHeadPic Wendy.Hu
