can't make player mp3 working
userHead Account cancelled 2017-06-09 06:42:58 2441 Views1 Replies
Hi there !
I recently bought a DFRduino Player MP3 SKU: TOY0008
Refering the wiki page https://www.dfrobot.com/wiki/index.php/ ... U:_TOY0008 I tried a very simple test but it seems I am missing something because no sound is playing
What I did :
- power player with an extern power supply 5V/2A
- pin wiring :
- no pin for OI
- TX to arduino mega RX
- RX to arduino mega TX
- no pin for 5v and GND (as I already power with external power supply)
- put an mp3 file named track.mp3 in the root directory of a Scandisk 4GB micro SD HC card
- wiring only one speaker
- SD card led is green
Here is the simple code for testing :
   Serial.begin(19200);
   delay(2000);                   //Wait for initialization
   Serial.println("\\:v 100");    //Set the volume, from 0 (minimum)-255 (maximum)
   delay(2000);
   Serial.println("\\track.mp3");
  delay(100);
I can hear a white noise through the speaker
Hope you'll be able to help me
Jean
2017-06-19 23:02:31 Hi
Please use the code follows to test:
Serial1.begin(19200);
delay(2000); // Wait for initialization
Serial1.println("\\:v 10"); // Set the volume, from 0 (minimum)-255 (maximum)
delay(50);
delay(50000); // the delay needs to be long enough to
Serial1.println("\\:n"); // play next
userHeadPic robert.chen
