Ts-01 Body Temperature Sensor
userHead Account cancelled 2021-03-04 00:45:32 797 Views1 Replies
I want to use it to measure human body temperature. I have a few questions about the sensor on this topic.
-Has this product worked previously about this project?
-Does the product have disadvantages in measuring human body temperature?
-Can we trust the document values about the fov value?
-Which of these products do you recommend?
50cm and 116 cm are the ideal measuring range for us but we want professional help.
https://www.dfrobot.com/product-1745.html
https://www.dfrobot.com/product-1824.html
2021-03-08 16:44:18 This product has not been used to test human body temperature before.
It measures the human body temperature at room temperature with an error of 0.5℃.
Regarding its FOV value, we have tested it and it is the same as in the document.
The choice of these two products depends on what kind of signal you want to obtain. The sensor itself outputs an IIC signal, SEN0263 outputs raw data, and SEN0264 is a converted analog signal.
userHeadPic 347945801
