Using DFR0300 - Signal Conversion Board (Transmitter) V2 with an E201WM Industrial EC probe
userHead Account cancelled 2021-03-13 15:47:12 551 Views1 Replies
I'm trying to build an automated hydroponics system using The DFR0300 kit. I've read that the EC probe that comes with this kit is a laboratory grade probe that can't be immersed for long periods of time. Following the advice given in https://blog.quickbird.uk/ec-and-ph-sen ... b77071f091, I got an E201WM K=1 probe. This is an industrial grade probe with a BNC connector just like the one in the kit.
I'm trying to figure out if the provided dfrobot probe can be swapped out with this E201WM probe with no changes to the DFRobot_EC library.
2021-03-13 22:20:56 We currently do not have a physical test of this probe and cannot give you an accurate answer. userHeadPic 347945801
