REQ: SHT31 - Address change on SKU:SEN0385, multiple sensor on single board
userHead killeriq 2021-04-27 14:47:16 760 Views3 Replies
I haven't found anything related to it....
I have this SHT31 sensor and found this guide https://wiki.dfrobot.com/SHT31_Temperat ... KU_SEN0385
My problem is that i have no clue how to change 0x44 address to 0x45.
They say in the code:
* @n When the ADR is connected to VDD, the chip I2C address is 0x45.
* @n When the ADR is connected to GND, the chip I2C address is 0x44.
1. But when i opened it and removed plastic sealing i see only this...so i assume it cant be changed easily :(
see pics
2. I have also other type of SHT31 sensors , where i should bridge 2 connections in order to change address, but not sure which ones. Haven't found any guide to that...
3. How to solve if i would like to use 3-4x SHT31 sensor in my project? on Cable length around 4 meters each.
As i want to replace DHT22 which are becoming faulty after few weeks, but they were easy to add on PINs without limitations
On since i2C i can add 2x SHT31 (if ill be able to change address) , but how to manage others? (im using also LCD on i2C)
I read about software i2C but not sure how reliable is it.
Also Multiplexer - here might be possible that ill could connect it on 2m long cable and this way i could have 4x 2m sensor on it. But again not sure about stability...
Any tips would be appreciated , thanks!
icon sht31c.jpg Download(0)
icon sht31b.jpg Download(0)
icon sht31a.jpg Download(0)
2021-04-30 21:49:29 You can see this kind of products in our wiki, we will all lead out the pins if you can change the IIC address. I don’t know what the AD and AL pins of the purple product mean, after all, I don’t have any information about it. userHeadPic 347945801
2021-04-28 14:34:33 Not even the Purple ones? userHeadPic killeriq
2021-04-28 00:15:52 These products of yours do not have pins that can change the IIC address. userHeadPic 347945801
