Object Classification on Arduino
anonymous 2021-04-27 17:41:36 3990 Views3 Replies We have been using the Huskylen since kickstarter days across a range of platforms and applications. It is a fantastic device.
My students are currently doing a project to automatically sort a recycling stream into different types of materials.
We are using a Huskylens interfaced via I2C into an Arduino.
The Husklens has been loaded with the classification firmware and successfully trained for the objects.
I have been able to get it running using a micro:bit programmed in MakeCode.
Unfortunately the sample code for Arduino seems to only return ID1 regardless of the object being correctly detected by the Huskylens.
Can anyone please provide assistance?
2021-05-10 16:43:22 This is getting very frustrating
I downloaded the Mind+ software and see how it would work.
I found a tutorial on using the Huskylens but the options in the tutorial were not available to me (domestic software only ?)
All I need in one working sample showing the Hushlens working on Arduino in Object Classification mode. The existing sample code does not work.
Can anyone help?
anonymous
Can anyone help?
anonymous 2021-04-30 22:28:23 You can try Mind+, which is similar to makecode, and you may be able to find arduino ideas from it.
347945801
347945801
