3d gesture sensor test code returns nothing
blackluc_d2 2017-06-23 13:43:52 1776 Views4 Replies Before getting deeper into it, I've tried and tried again the sample code for the 3d gesture sensor and it returns absolutely nothing. I was wondering if I received a dead sensor or simply if the sample code has issues.
2017-06-27 22:07:54 Hi
What I found out is when you using it, you should move slowly along the direction it shows like the attached picture, I am not sure about why your sensor is not working, you can require a replacement if it really doesn't work.
robert.chen
robert.chen 2017-06-27 06:46:18 Well the wiring is pretty simple and I have redid it a few times. I understand a simple human error can occur, but right now it's wired exactly as shown in the wiki and it's using the exact same code and libraries and it does not work. Faulty sensor?
blackluc_d2
blackluc_d2 2017-06-27 01:49:31 It works well for me, check the wiring first, remember move your hand slowly along the direction shows on the sensor
robert.chen
robert.chen 2017-06-26 18:43:43 I tried again and again and I still did not manage to get this sensor working :/
blackluc_d2
blackluc_d2
