Problem with SEN0186 Weather Station and ESP32
Account cancelled 2021-10-23 02:53:19 1157 Views2 Replies Hi!
I am using this Weather Station with an ESP32 microcontroller.
APRS_Weather_Station_Sensor_Kit_SEN0186
In the wiki, the frame has the following structure:
c000s000g000t082r000p000h48b10022*3C
However, when I read from the RX, the data what I receive is:
A3311B293C0000D0000E0000F0000G0000H0000I0000J0000K0000L0267M367N09999O.....*57
A3311B293C0000D0000E0000F0000G0000H0000I0000J0000K0000L0267M366N09999O.....*56
What could be happening? It is not the same as the data on the wiki
Thanks!
Thanks!
2022-01-20 19:25:20 Its the output format.
There is a way to change the format from
c000s000g000t086r000p000h53b10020
Output 37 bytes per second, including the line feed Cr / LF at the end of the data.
Data resolution:
C000: wind direction angle, unit: degree.
S000: wind speed in miles per hour in the first minute
G000: Highest wind speed in the first 5 minutes in miles per hour
T086: Temperature (Fahrenheit)
R000: rainfall in the previous hour (0.01 inch)
P000: Rainfall in the first 24 hours (0.01 inches)
h53: humidity (0%=100%)
B10020: air pressure (0.1 hpa)
to....
Output format of professional measurement data (metric system):
JP3 short circuit, after power on, will enter the professional measurement mode, convenient for secondary development.
Format of professional measurement data:
A0789B000C0000D0000E0000F0000G0000H0000I0000J0000K0000L0209M703N10233
Output 71 bytes every 0.5 seconds, including line breaks (OD, OA) at the end of data
Data analysis:
A0789: wind direction measurement ad value.
B000: snbsp; wind direction angle value
C0000: real time wind speed frequency 1Hz
D0000: real time wind speed 0.1m/s
E0000:
F0000: the highest wind speed in the first 5 minutes is 0.1m/s
G0000: real-time rainfall bucket number, 0-9999, cycle count
H0000: rainfall volume in the previous minute, 0-9999
I0000 : 0.1mm of rain in the first 1 minute
J0000: Rain 0.1mm in the previous hour
K0000: rainfall in the first 24 hours 0.1mm
L0209: Temperature (Celsius), 0.1 degrees below zero, the first display symbol "-". Sensor support is required below zero.
M703: Humidity 0.1(0%=99%)
N10233 Air Pressure (0.1 hpa)
georgedlake
Data resolution:
to....
Data analysis:
E0000:
georgedlake
