SEN0161 + DFR0327 + RPi 3B
kia2882 2017-07-15 12:08:25 3189 Views5 Replies If I have the shield and Pi connected (via GPIO pins & serial) and the PH sensor plugged into A0 on the shield, how do I go about getting the sensor value on the Pi?
Is it possible to get the analog value from the shield on the Pi (using wiringpi)? Also, I have a headless setup using a mac and vnc is not an options, how could go about programing the arduino?
2018-06-30 10:54:35 Hey,
What did you mean by that? Because I also have a problems that the board (and therefor the serial port) is not recognized by the RPi3.
Martijn
martijnvanderklauw
Martijn
martijnvanderklauw 2017-07-22 09:43:49 Whoops, had set dtoverlay=dwc2 which was preventing usb serial communication. All fixed.
kia2882
kia2882 2017-07-22 06:41:46 having some trouble setting up serial communication between the RPi 3 and DFR0327. Any guidance would be greatly appreciated.
kia2882
kia2882 2017-07-16 15:21:31 Ignore my last question, I was able to start tightvnc server on the raspberry pi and access it via a mac.
kia2882
kia2882
